Thread: Who is the primary for brightness?
    Oct 2012
    376
    Default Who is the primary for brightness?
    From what I can see, you can set brightness in the Xlights models, or in the "driver" board....Falcon or ESpixelsticks (and the like). So does the pixel hardware drivers override what you set in Xlights?
    Jan 2021
    1,162
    Default Re: Who is the primary for brightness?
    The primary is in the Controller tab. Then any brightness you set in your models would override that, then brightness in your effects would override that.
    Framingham, MA
    611
    Actually, they don't "override", they are additive. Thus if you set the brightness of the model to 50% and then set the brightness on the controller to 50%, the result is 25% brightness.
    Dan Kulp
    Jan 2021
    1,162
    The guys in the Xlights room told me they overrode, like 1 1/2 years ago. If they're additive, they I am very confused how that stacks with the gamma curve.
