Thread: Who is the primary for brightness?
    Oct 2012
    367
    Default Who is the primary for brightness?
    From what I can see, you can set brightness in the Xlights models, or in the "driver" board....Falcon or ESpixelsticks (and the like). So does the pixel hardware drivers override what you set in Xlights?
    Jan 2021
    850
    Default Re: Who is the primary for brightness?
    The primary is in the Controller tab. Then any brightness you set in your models would override that, then brightness in your effects would override that.
    2,509
    If you set a brightness on the actual controller, it will dim everything that a sequence has in it. So, you can dim a whole controller without having to render the sequence.
