Results 1 to 10 of 12
Thread: Automotive Connectors & Polarity
    Dec 2020
    277
    Default Automotive Connectors & Polarity
    With these automotive connectors is there some convention which one is negative and which one positive?
    https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
    Oct 2012
    369
    Default Re: Automotive Connectors & Polarity
    Polarity is what you decide since there are pins to solder to. Just be consistent of course. And fuse your positive rail.
    Dec 2020
    277
    I suspected there is no norm except my norm. I just wanted to make sure before I start creating a bunch of those. Thanks!
    Shalimar,FL
    46
    I am using A=+ and B=-
    Chambersburg, PA
    1,250
    My method is 1 is always +, and - is always the last pin. (I use 2,3, and 4 pin in my display)
    2016 - No Display
    Dec 2020
    277
    Hmm, I was going to do this the opposite way, i.e. pin 1 being -/ground/reference and then other pins measuring against pin 1. Is there any particular reason you have + on pin 1 or is this just preference?
    Mar 2015
    Bloomingdale Ga
    592
    You set your own standard. Do it how ever it's easier for you to do or remember.
    I have 2pin and 3pin. On 2pin I always put V+ or D+ on pin 1 and V- on pin2. On 3pin V+ on pin 1, D+ in the middle pin2, and V- on pin 3. That is my standard and I have it wrote down and stick to it. Some of my connectors don't have numbers so I have a male and female made up with my standard with red, green and black wire to represent V+, D+ and V- so I can refer to it to make sure I put them together properly even without numbers on them.
    A bit to get use to but I really like using them on all my pixels.
    Chambersburg, PA
    1,250
    Quote Originally Posted by munu View Post
    No reason other than it is easy for me to remember. You just need to be consistent.
    2016 - No Display
    Jul 2019
    United Kingdom
    203
    I use 2, 3 and 4 pin versions of those on my setup. I'm not aware of any specific conventions.
    Nov 2021
    6
    I'm using A as positive and landscape wire using the side with labeling as positive. Just the way I figured felt right.
