Results 1 to 10 of 18
Thread: Vixen 2.1.4.0 with Windows 7 64 bit issue
    On The Dark Side Of The Moon (Really, LI - NY)
    463
    Default Vixen 2.1.4.0 with Windows 7 64 bit issue
    Hello All!
    It has been a while since I had signed into the forums as I have stopped using sound to lights for Christmas about 4 or 5 years ago. I continued to use Vixen for my Halloween shows for a signing pumpkin display but I had stopped that 3 years ago. This year I wanted to revitalize the singing pumpkin display and I wanted to use Vixen 2.1.4.0 on Windows 7 (64 bit) and I have run into an issue.
    Vixen starts up fine, but when I go to load the sequence up, nothing appears on screen. The song plays, but the preview display doesn't come up and nor do the channels.
    I have .Net Framework 4.7.2 on my system as I believe the .Net Framework was one of dependencies.
    It is possible that I am just not remembering what to do to set this up properly. I have searched the forum to see if running this version of Vixen was possible on 64 bit Windows 7, and read that it does run. I figured I might have had problems with configuring the COM port, but alas, I can't even get the sequence to show up on screen with the channels and preview display.
    Any help would be appreciated. Here are some more of my system stats:
    Intel i7 6700k CPU
    16 gig ram
    A few terrabytes HD space.
    Graphic Card: GTX 1080 TI
    Thank you,
    Geo
    New Mexico
    4,092
    Default Re: Vixen 2.1.4.0 with Windows 7 64 bit issue
    Deleted
    New Mexico
    4,092
    Wow, been a while. Your PC has WAY more than enough horsepower to run Vixen (or whatever you want ) As I recall, your sequence must be attached to a 'profile' to show up on your screen. You might check that out. A sequence can also be 'flattened' to a profile so that they travel together.
    Feb 2008
    Warminster, PA
    1,910
    With Vixen 2.1 you also need to install .Net 3.5. There is a workaround to get it to work with .net 4.x if you can't get 3.5 installed though.
    The workaround is to add
    <startup>
    <supportedRuntime version="4.0"/>
    </startup>
    to your Vixen.exe.config file. You have to add it within the <configuration> tags.
    Chris
    Feb 2008
    Warminster, PA
    1,910
    If your computer is connected to the internet, I highly recommend upgrading to Windows 10 though, for security reasons. If you do, you'll still need to install .net 3.5.
    Chris
    463
    Hello guys,
    I don't know what is going on with this forum, but certain pages are in text only format and others have the full graphics. I don't know what I am doing in text mode, so I am giving it a shot, but someone has to check this issue out as just plain navigating in text mode is a PAIN!
    Getting back to my issue this is what I found:
    .NET Framework 3.5 refuses to load on my system. .NET 4.x only loads. As such I have upgraded it now to 4.8.
    When I had saved my Vixen files, there were "flattened" with the profiles associated with the files. For some reason, Vixen is separating them. When I re-associate the profile with the file, I do get the preview back, however, the sequence is empty. How do I get it to show my sequences? Also, Why does Vixen under Windows 7 separate my sequences from the files? THat wasn't the case when I used Windows XP. Is this because it is refusing to work with .NET framework 4.8?
    Feb 2008
    Warminster, PA
    1,910
    You can either use profiles or keep everything in each sequence. Its really just a preference for that one.
    I would suggest using .net 3.5 if possible, only because that has been tested tried and true. I have, however, been running it in .net 4.8 for awhile now with no issues.
    What error are you getting for .net 3.5?
    If you post your sequence and profile(maybe in a zip file), I can take a look.
    Chris
    463
    Well, earlier I managed to find some of my older sequences and they DO show up intact. I have to see if the Renard controller works, but this computer doesn't have a com port, so I have to get an adapter to check if the controller works. However, 2 sequences I don't have an older version of. I might have to set up my old computer and see if I can get the sequences from there to test them out. So now with this information, I feel that the .Net 4.8 isn't the issue.
    I am wondering if I had Vixen 2.5 on the newer sequences. I was reading that 2.5 sequences don't run on 2.1.X.X
    It is isn't a message. When I click on the installer, it looks like it is 'unpacking' something in a small window, but then it just goes away and nothing happens. No error message or anything. However, if I install any variant of .NET Framework 4.x, it will properly install.
    How do you do that? I know you can add pictures and videos, but I don't know how to post file attachments.
    Oh! BTW, I figured out what was wrong with this website running in text mode. For some reason, it just doesn't like Firefox. I have Chrome as well and it is working fine with that.
    Geo
    Feb 2008
    Warminster, PA
    1,910
    I wonder if .net 3.5 is already installed then. I think you would have gotten a popup if it wasn't.
    I know there's a converter for 2.5 back to 2.1 but I don't have a copy of it. Maybe someone who has it will chime in.
    Chris
    Feb 2008
    Warminster, PA
    1,910
    Oh, i found it. Here it is.
    Also, you can add files by clicking the Go Advanced button when you're replying.
    Attached Files Attached Files
    Chris
