VAST FM Transmitter | No Audio via USB running Windows 10
Hi all,
I am using 2 of the VAST INT FM Transmitter and cannot get Audio working when connected via USB to any PC.
I tried:
1. VLC -> Audio Device : HIFI FMT
2. Set the FM Transmitter device as default Audio Device for Windows
NO Sound transmitted over the Air.
The Sound level indicator if the GUI is indicating something.
Re: VAST FM Transmitter | No Audio via USB running Windows 10
Did you run a scan in your area to make sure the frequency was unused? You could try externally supplying the 5 volts dc and use the aux input to see it its a windows driver problem.
Love LEDs!
Some background information:
The device is used to test tuner modules and is directly connected to the antenna input.
In any case, RDS Text and station name is received on the frequency used by the transmitter without issues.
- You may not post replies
- You may not edit your posts
Forum Rules
