Thread: FPP adjust volume at set times
    Jan 2021
    857
    Default FPP adjust volume at set times
    Curious how you execute an FPP command at a set time? Namely, Volume Set. My street block's got a lot of hustle and bustle around 6, so need the volume up. But 11pm needs to be volume down, or my neighbors start not to like me. I'm not doing FM. I'm willing to break up my playlist scheduler into two pieces, but I don't see how to insert an FPP command into a playlist?
    Framingham, MA
    594
    Default Re: FPP adjust volume at set times
    Assuming FPP 5 or FPP 6, in the FPP schedule, add an entry at the time you want, change the "Schedule Type" from playlist to "Command", and use the Volume Set command. Commands are scheduled and run separate from playlists.
    Dan Kulp
    Jan 2021
    857
    Thanks, I found it. This was on FPP 5.3.1, which is what i got pre-installed on the Kulp board from you.
