Results 1 to 4 of 4
Thread: HolidayCoro Tune To sign - xLights Model
    Jul 2022
    11
    Default HolidayCoro Tune To sign - xLights Model
    Anyone know where to download the xLigights model for their prop, or has anyone made one? I can't seem to locate it through the xLights interface or their website.
    https://www.holidaycoro.com/Tune-To-...odes-p/350.htm
    TIA
    2,374
    Default Re: HolidayCoro Tune To sign - xLights Model
    Each one would be different based on the frequency. You will need to make your own.
    Jul 2022
    11
    So there's no even stand in for the "Tune to" I take it - seems like a miss.... maybe I'll make one and export it for others.
    Nov 2015
    30
    Here is a model I threw together last night after putting my pixels in the sign, since everyone's frequency will be different, you could just change the numbers around. Mine is for 87.9, so if yours is the same your good to go, else you can change the frequency but the "Tune To" will not change. The other change you may want to make since its strictly preference is the wiring route since again its strictly based on preference and/or need. Note the reason I zipped a single file is because it did not like the xmodel extension.
    Hope it helps some, JerryG
    Attached Files Attached Files
