Results 1 to 7 of 7
Thread: Wire Length Question
    Dec 2020
    88
    Default Wire Length Question
    I have some Boscoyo 99-pixel canes and 105-pixel trees (7 canes, 8 trees). I have a good idea where they will end up in my yard, and also where the PSUs will be. I'm using 5v pixels, with dedicated 14ga power wires going to the middle of each prop. Some of the props will be only a few feet away from a PSU, while others may be as far as 20'. I was considering making all power wires the same length - regardless of distance to PSU, thinking that then they would all have the same resistance, and thus would be the same relative brightness. But that's also going to be a LOT of extra wire, which is both more costly, and also will be that much MORE wire in the yard. Will there be a significant brightness difference between using 3' of wiring vs 20'? Am I over thinking this too much? Thoughts or experiences appreciated!
    -pc
    5,874
    Default Re: Wire Length Question
    Coils of wire on the ground create an inductor which can cause a drop in voltage. Also wire resistance is ohms per foot. Every foot increases energy lost as heat.
    Feb 2008
    Warminster, PA
    1,845
    I don't do pixel so this is just a curiosity question. What is the typical way people handle this then, use 12v power supplies with buck converters or many smaller 5v power supplies?
    Chris
    5,853
    You're overthinking the matter. I don't think that anyone would notice any difference in brightness, especially at anything less than 100%.
    5,874
    It depends. I have some very dense props and those have 5v supplies right at the prop. My arches and Candy canes have 5v psus in a cluster. My 6' trees have one PSU per two trees. My house pixels use 24v PSUs with lots of 5v bucks. A typical window has 8 bucks. My hanging (inverted) arches and roof outline have a buck every 25 pixels. My snowflakes have a buck on every arm, etc.
    Feb 2008
    Warminster, PA
    1,845
    Thanks. That makes sense.
    Chris
    Dec 2020
    88
    Thanks all for the feedback! I went with varying lengths of wire based on proximity to PSU.
