Results 1 to 4 of 4
Thread: Add A Spotlight Feature
    Dec 2017
    6
    Default Add A Spotlight Feature
    There may already be a way to do this, but I am new enough that I have not been able to figure it out. Is there a way to move a spotlight effect over the full preview? Going from full off and sweep the full length of the preview. This would be up and down as well as left to right. Possibly set a point on the preview to make the sweep directional?
    Jul 2019
    United Kingdom
    113
    Default Re: Add A Spotlight Feature
    I think it might be possible using the 'picture' effect. Make an image which is a white circle on a black background (say) then move that by adding curves to the X and Y offset parameters, so they change over time. The beginning of my squid game red light/green light sequence used this effect to add the circle, triangle and square to the megatree, they are just simple black and white bitmaps.I just fade them in and out, but they could be animated using the offset sliders.
    The other option would be to make a video of what you want (you could use motion graphics software like AfterEffects to move a white circle around) and map the video to your pixels.
    Oct 2009
    41
    Are you wanting to move a round group of pixels around your display? If yes, the Morph Effect has a mode where you draw a circle and then you choose how to animate it over time.
    Jul 2019
    United Kingdom
    113
    Nice - I have learned something there too! So that's three ways of doing it, I don't think it needs its own dedicated effect/filter built.
