Small show? You might be able to Bluetooth it. At least, until a Pi 4 becomes available.
Long story, short: Anyone successfully using a Pi 400 to run a show including audio?
I ran a small show last year by running xlights on a laptop connected to a Falcon F16v4. This was acceptable with my laptop and Falcon inside the garage. This year will be a significantly bigger show and I don't want to run all the cables under the garage door. So, since it will be outside, I am intending to use a Raspberry Pi. Unfortunately, they seem to be hard to find, and I know nothing about Raspberry Pis. The one I could find to purchase is the Raspberry Pi 400. Seemed like a good option for a Pi newbie until I started investigating audio options. Sounds like it isn't very audio friendly. One of the two micro-hdmi transmits an audio signal, but it doesn't sound like the typical USB soundcard works with it. Anyone with insight or experience?
In general a rPI is a small Linux computer. The 400 is actually a modified rPI 4. It has the Ethernet and 5 USB ports exposed. Not sure how big the flash size is but it has everything you need to run a show (plus a moderately annoying keyboard). You can connect a USB based sound blaster audio adapter (or other type) to it and use the Ethernet port to drive the show.
Have you seen the DACBerry 400? I'm not using one, but it looks like it might "answer the mail"...
https://www.okdo.com/us/p/osa-dacber...SABEgKZEfD_BwE
Yeah, you can connect it via Bluetooth to a Bluetooth speaker, and not have to buy any other special hardware. It's just I find your Pi 400 setup suboptimal, and mostly I think you're doing it because that is what you had available. I mean why buy other hardware if you're only going to switch it again later.
The reason other people don't do Bluetooth more often is because the audio playback's timing is not as tight with the lights. I'm not convinced that is too much of a concern for you. Just try the Bluetooth first, and if it doesn't work, what have you lost? You learned something.
Timing is definitely a concern for me. I'm a musician, so even if my show is small so far, it would drive me crazy if it wasn't synced right. And, I do use an FM transmitter. I'm sure I could find some way to connect the bluetooth to an FM transmitter, but that would probably compound the latency issues.
What do you consider suboptimal about using the Pi 400? You're right that I'm doing it because it is what was available, so you may be right. Other than the possible audio issue, it looked to be as good a setup as a Raspberry Pi 4. But, as I said, I know next to nothing about Raspberry Pis.
