Page 43 of 44 FirstFirst ... 3341424344 LastLast
Results 421 to 430 of 435
Thread: PixelRadio, a DiY FM Transmitter with RDS RadioText
  1. #421
    Dec 2020
    286
    Default Re: PixelRadio, a DiY FM Transmitter with RDS RadioText
    I have a couple of IRF540N from a different project. Would the IRF540N work as a replacement for the IRLZ24NPbF? From the specs I would think so but I am not sure.
    https://www.infineon.com/cms/en/prod...annel/irf540n/
    Also does the board accommodate 1/4W or is the board designed for the smaller 1/8W resistors? I guess I could always mount them vertically but if this project also expects the smaller ones I might just buy a set.
  2. #422
    Nov 2021
    USA
    207
    Not a recommended sub. The IRF540N gate threshold is 4V. The ESP32 logic high is only 3.3V. So it's not a compatible MOSFET. If you will be using the optional "On Air" LED sign then you'll need to stuff a IRLZ24NPbF.
    One builder reported using 1/4W. They were satisfied with how it looked. However, I think you can get an assortment of 1/8W 5% from AliExpress for just a few dollars.
    - Thomas
  3. #423
    Chambersburg, PA
    1,290
    I have one or two extra PCB's for PixelRadio. If you would like one PM me.
    All gone, Sorry!
    2016 - No Display
    2021 - 10 RHL Simple Pi Pixel Controllers - 1 Master with 9 Remotes
  4. #424
    Jul 2022
    23
    Any good links to the external on air signs from anyone?
    Additionally, is the on-air sign similarly hooked up like the LED is so that it turns on when sensing music through the jack?
    Thanks!
  5. #425
    Nov 2021
    USA
    207
    If you want a desk top version then this LED sign looks good: https://www.aliexpress.us/item/2252799820237618.html
    For scale, this photo shows the 12V W300xH200mm version:
    For outdoor installations you can build your own 12V sign using a backboard populated with LEDs that spell "ON AIR, TUNE TO FM 88.9." Or paint a big sign and illuminate it with bright 12V LED spotlights (that are controlled by PixelRadio).
    The external On Air sign control port is synced with the front panel LED. They both turn on whenever the RF carrier is active and the test tone mode is disabled (Music Source enabled).
    https://github.com/thomastech/PixelR...re#on-air-sign
    - Thomas
  6. #426
    Nov 2013
    Morganton,North Carolina
    1,969
    Not getting audio or test tones using the Soundblaster 3. I've set things up in the FPP plugin also.
    What am I missing?
    UPDATE: Turned off Stereo and used Mono and things seem to be ok.
    (2) Kulp K32A-B
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    (1152) Pixel Boscoyo Matrix
    WIKI
    Become A Supporting Member
    Falcon Christmas
    Renard Controllers
  7. #427
    Nov 2021
    USA
    207
    That is an unexpected solution. Especially since the test tones are independent of the external audio.
    At this point it's a mystery on why you need to use the mono broadcast mode. But check / resolder U8, C8, C9, and the QN8027 module. Use the test tones during your troubleshooting since that would eliminate any issues related to external audio.
    - Thomas
  8. #428
    Nov 2013
    1,969
    Quote Originally Posted by ThomasLED View Post
    - Thomas
    Ok,using the test tones or audio from the Soundblaster,the audio has alot of static on Stereo. Using mono,the static is there,but way less. I'll have to troubleshoot more tomorrow.
    (2) Kulp K32A-B
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Falcon Christmas
    Renard Controllers
  9. #429
    Nov 2021
    USA
    207
    Mono mode disables the FM pilot tone and reduces RF bandwidth (better S/N). This improves reception of weak signals and is the main reason the feature exists.
    But if you need stereo audio then there might be an easy remedy. For example, perhaps this issue is interference from an adjacent FM broadcaster or dirty RF source. Try tuning to other unused areas of the FM dial. Also try moving the receiver to other test locations that provide better reception. In some situations merely changing antenna position may help.
    - Thomas
  10. #430
    Dec 2020
    286
    Quote Originally Posted by munu View Post
    <snip>
    To answer my own question, the board is designed for 1/8W resistors. 1/4W resistors won't lay flat unless you do some bending or mount them vertically. I got my 1/8W resistors today so all is good
