Page 29 of 35 FirstFirst ... 192728293031 ... LastLast
Results 281 to 290 of 341
Thread: PixelRadio, a DiY FM Transmitter with RDS RadioText
  1. #281
    Chambersburg, PA
    1,215
    Default Re: PixelRadio, a DiY FM Transmitter with RDS RadioText
    I have not built one but that message is tied to the RF VDC being "bad".
    (2) ESP32's VDC ADC. We use ADC1_CHANNEL_0, which is GPIO 36.
    This part of schematic:
    Attachment 45947
    Usual things. Check your solder is good. Check values of resistors. Check voltage before the resistors.
    You built two right? Are both of them saying that?
    Yes, I built 2. I have already checked my soldering and they both look good. I will check to see if I used a incorrect part during assembly of both.
    2016 - No Display
  2. #282
    Nov 2021
    USA
    167
    When I open the UI on both of my builds I am getting BAD-VDC showing up under "Radio Status". What do I need to check?
    I suspect you have not installed the jumper that is required at J9.
    Please see the Jumper Wires section:
    https://github.com/thomastech/PixelR...e#jumper-wires
    If the J9 jumper was installed then please report the two voltages displayed on the Diag tab.
    EDIT: I reviewed the assembled PCB photos you posted last May. I can see that you have a 2-Pin header installed at J9, which is great. But you need to install the shorting block too.
    - Thomas
  3. #283
    Chambersburg, PA
    1,215
    Quote Originally Posted by ThomasLED View Post
    - Thomas
    Installing the jumper on J9 fixed my issue on PixelRadio.26 I will continue on testing with this unit.
    However, when I install the jumper on J9 on PixelRadio.25, the green light on the ESP32 goes out and I lose my wireless connection. When I remove the jumper the green light comes back and I can reconnect to the UI. I have completed another visual inspection of the .25 board and don't see anything suspect. I have yet to put a multimeter on the resistors to double check, but comparing the stripes on each between the two boards has not surfaced any discrepancies. Where do I go next?
    2016 - No Display
  4. #284
    Nov 2021
    USA
    167
    Good to hear.
    ... on PixelRadio.25, the green light on the ESP32 goes out and I lose my wireless connection. When I remove the jumper the green light comes back and I can reconnect to the UI. I have completed another visual inspection of the .25 board and don't see anything suspect.
    That suggests that the main power supply is shutting down when the jumper is installed.
    My first thought is that there is a short in the 9V power supply circuit (on the output side of J9) or the 12VDC wall wart is bad. So that's where I suggest you look.
    The initial troubleshooting tool should be your eyes. Inspect every soldered connection in the RF Amp area and verify none have solder shorts to the ground plane or nearby pads.
    If that does not solve the problem then perform general power supply troubleshooting. I'd start by measuring the voltage on C16. Should be > +11.5VDC with J9 removed and should not change much when the jumper is installed.
    Next check the voltage on C17. Should be approx +5.0VDC with J9 removed and should not change when the jumper is installed.
    If the previous voltages are OK then check the voltage on C20. Should be approx +9.0VDC with J9 removed and should not change when the jumper is installed.
    BTW, you have a working unit. So you can take ohm or volts measurements from it and use the info to locate the problem on the bad board.
    - Thomas
  5. #285
    Chambersburg, PA
    1,215
    - Thomas
    Found my problem! I now have 2 working PixelRadios! Thanks for your help!
    2016 - No Display
  6. #286
    Nov 2021
    USA
    167
    You are welcome. Glad to hear that both PixelRadios are working.
    - Thomas
  7. #287
    3,331
    For future reference, what did you find?
    Live, Laugh, Love.
  8. #288
    Chambersburg, PA
    1,215
    It was either a solder bridge or a poorly soldered connection. I reflowed a couple of different joints.
    2016 - No Display
  9. #289
    3,331
    Live, Laugh, Love.
  10. #290
    Mar 2015
    Bloomingdale Ga
    564
    I have 3 boards that have everything soldered on them except the antenna jack, FM transmitter and the wifi board. I'm offering them up to anyone who wants one just pay actual shipping.
