That's a feature not a bug.
There's no charge for that.
The build of my 2 Pixel Radios is complete, now I have to figure out the installation of the software, hopefully, tonight or tomorrow night. I will also be printing the ends for the enclosure in the next couple of days.
2016 - No Display
2021 - 10 RHL Simple Pi Pixel Controllers - 1 Master with 9 Remotes
I am in the process of trying to install the PlatformIO IDE to Visual Studio Code. My screen has been like this for over 1/2 an hour now with no progress.
Suggestions?
2016 - No Display
Confirm your version of Python is supported by Platformio. Should be V3.6 or greater. I'm using Python V3.7.My screen has been like this for over 1/2 an hour now with no progress.
https://docs.platformio.org/en/lates...install-python
Be sure to review the installation doc:
https://docs.platformio.org/en/lates...al-environment
EDIT: Disable your virus/malware protection *before* the installation.
If everything looks correct then do a Hail Mary: close Platformio, reboot, and try again.
If still no joy then I suggest posting the issue on the Platformio Github site.
- Thomas
Last edited by ThomasLED; 05-05-2022 at 09:47 PM. Reason: disable virus protection
@TomL8345, hopefully you were unable to resolve the problem. But if still no joy and are installing on Windows, then please open a command prompt and run these two commands:
Report the response for each command. This will tell us if your Win machine has the correct ports enabled. The expected response would be:Code:netsh int ipv4 show dynamicport tcp netsh int ipv6 show dynamicport tcp
- ThomasCode:Start Port : 49152 Number of Ports : 16384
Just had the same issue yesterday with my reinstall (I had other problems with one of my projects). If you watch carefully, there is a popup that indicates python is missing. Did you remember to check the "Add python path to environment" box? I did. On the popup there is a "I Have Python installed" button. Click it and a new menu comes up at the top of the window asking for a path to python, paste in the path. Then restart VS. The error will come up again but after a minute you will see that the install is actually making progress. This worked for me. YMMV
I still have to program and install the ESP32 as well as installing the CD4052 chip. You may notice that I used double row headers for the ESP32 (that was what I had on hand) I just pulled out 1 row of pins from each before soldering.
20220506_092722_HDR-640.jpg 20220506_092822_HDR-640.jpg 20220506_092954_HDR-640.jpg 20220506_093014_HDR-640.jpg
2016 - No Display
2016 - No Display
