Sorry if this was asked before but there are like 43 pages in this thread. As you can see from the picture I am still working on the board. Terrible soldering (ordered some flux because the solder puddled up high on the soldering iron). My question is regarding the housing, though. There are no guides to put the board in. The board is also a couple of mm to large to squeeze it in (you can see how the housing is actually bending). I have some 'stand off screws' to elevate the board but the fact that it doesn't fit into the housing suggest I am doing something wrong.
Never mind, I see there is a groove at the very bottom of the case...
Re-flowed those those parts I saw,didn't see a U8 on the board or in the BOM,unless I overlooked it,and it didn't make a difference. I did however notice that when my hand or finger was near or touching the L7 jumper wire,there was almost complete silence on Stereo mode.
(1)Falcon PI Player (Running the show)
(2) Kulp K32A-B
(1)Renard SS16
(1)Renard SS24
(1)EDM-LCD-CS-EP
(20)P10 Panels
(1152) Pixel Boscoyo Matrix
WIKI
Become A Supporting Member
Falcon Christmas
Renard Controllers
I just be doing something wrong but I am not sure what. C3, the cap in the upper middle is a lot smaller than what the PCB indicates. But it is 100uF/16V from what I can read. Also C10 (lower right) is a lot smaller than the reference image shows. It's a bit confusing because C10 is supposed to be 0.01uF/50V and the other 3 around it are supposed to be 0.01uF/50V so they should be larger. Is C10 just oversized in the reference image (something like 63V or higher)?
C-10 is .01 uF 50V and C-4,C-5 and C-11 are .1 uF 50V so yes C-10 is larger.
And C-3 is 100uF 16V
You are not doing anything wrong. I don't want to speak for Thomas but I assume he made changes and for whatever reason the Gerber files were not updated to reflect the changes or something entirely different, but if you stick to the parts list you should be OK.
I stopped working on it for a bit, and decided to work on another one of the boards that I bought (bought multiples of everything) and I had the same result. The color bands were hard to read and I'm PRETTY sure you were spot on that the R1 resistor was incorrect. Waiting for Amazon to ship me some (comparatively overpriced) replacements of the correct ones. Desoldering it was a pain, but I think my board is ready for it. If not....well I have 2 more spares.....
Thanks again - stay tuned.
Ok @ThomasLED more LED light woes - I remade a new build again on another board, but this time, the LED is staying on regardless of any input being in the jack. Thoughts?
Need more info:I remade a new build again on another board, but this time, the LED is staying on regardless of any input being in the jack. Thoughts?
1. Does your browser (Firefox, Chrome, Edge) connect to PixelRadio?
2. While connected via the browser: Does the LED turn off when you enable the "Test Tone" Feature?
- Thomas
1. Yes!
2. Yes as well.
If the LED turns off when the test tone feature is working then all is good.
- Thomas
