Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Getting Started with ESP32 and the ESPixelstick FW
    5,796
    Default Re: Getting Started with ESP32 and the ESPixelstick FW
    Please send me a copy of your platform user ini file
    Marietta, GA
    307
    Everything is commented out in my platform_user.ini file since the autodetect of the com port seems to work fine.
    Well, everything but the line [env] is commented out just like the sample user ini file.
    Happy to send but it's pretty boring.
    -Chris
    2012: 3 Renard SS24's for 72 channels... 6236 lights... 4 songs... powered by HLS
    2013-2020 - a little bit more each year...
    2021: 4 Renard SS boards driving 88 channels... 32 FAST tubes.... 7 ESPixelsticks driving 3000 pixels... 10 songs... powered by xLights and FPP
    5,796
    Does the end of the output look like this:
    ========================================= [SUCCESS] Took 26.25 seconds =========================================
    Environment Status Duration
    d1_mini_mhetesp32minikit SUCCESS 00:00:26.249
    ========================================== 1 succeeded in 00:00:26.249 ==========================================
    Marietta, GA
    307
    similar....
    ================================================== =============== [SUCCESS] Took 43.85 seconds ================================================== ===============
    d1_mini_mhetesp32devkit SUCCESS 00:00:43.855
    ================================================== =============== 1 succeeded in 00:00:43.855 ================================================== ===============
    -Chris
    5,796
    And the build is using the GPIO defs file I made and running the build on an ESP results in LittleFS file access errors. I have yet to get PlatformIO to upload to my target device but I suspect I am going to see the FS getting cleared by the uploader. I initially had that issue in a version of the ESPFlash tool.
    5,796
    I finally got the platformio build to upload and can reproduce your error.
    Build from Arduino IDE:
    Wrote 1134544 bytes (696510 compressed) at 0x00010000 in 11.9 seconds (effective 765.7 kbit/s)...
    Boots and runs just fine
    Same code built and uploaded on platformio:
    Wrote 1146368 bytes (704521 compressed) at 0x00010000 in 11.9 seconds (effective 773.1 kbit/s)...
    Boot fails:
    10:02:20.375 -> [ ESP] ESPixelStick v4.x-dev (Jan 27 2022 - 09:52:39)
    10:02:20.375 -> [ ESP] v4.4-beta1-189-ga79dc75f0a
    10:02:20.375 -> [FileMgr] Flash file system initialized.
    10:02:20.704 -> [ 1209][E][sd_diskio.cpp:199] sdCommand(): Card Failed! cmd: 0x00
    10:02:20.704 -> [ 1210][E][sd_diskio.cpp:795] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
    10:02:20.983 -> [ 1516][E][sd_diskio.cpp:199] sdCommand(): Card Failed! cmd: 0x00
    I suspect there is a difference in the core files used
    So far I have not checked the ESP8266 to see if it has an issue.
    5,796
    ESP8266 is working fine. It turns out the error messages have nothing to do with LittleFS. The are all about the fact the SD Card is not installed. When I added an SD card, all of the errors went away. Not sure why the latest core is putting up messages on a platformio build and not on an arduino build. The important thing is that other than the annoying messages, the ESP32 build is working.
    Marietta, GA
    307
    My error is different and I do have an SD card installed. I remember it outputting some of the file names installed on the SD card.
    I went in the office today but when I get home tonight will get a fresh look at the error message and post it.
    -Chris
  9. #19
    7,616
    -Ah .......those little f's again . they haunted me ! lol
  10. #20
    5,796
    I am sure they are STILL keeping you up at night.
