Thread: Looking for info on Ren24LV
    Colorado Springs
    4,053
    Default Looking for info on Ren24LV
    This goes back a long way. For those that used to use the Ren24LV, you will recall that an SSR plugged in to the board will not have it's indicator light active. Frank once posted a fix for this that required a jumper wire to be installed. Do any of you old hands remember what the exact fix was? I seem to recall that a ground wire needed to be installed to pin 7 on the output jacks and to the input jack, as the ground was not included on the traces. Anyone?
    9,505
    Default Re: Looking for info on Ren24LV
    I thought that was the problem on Budude's Renard48LSD, not Frank's 24LV.
    http://digwdf.org/store/
    Even though the DIGWDF Store has been closed for almost three years, it's still awesome!
    Colorado Springs
    4,053
    Not sure about the LSD, but it is def an issue on the LV....... so, no one remembers this fix?
