Vixen Will not export .tim to .fseq
When I attempt to export to .fseq I click on start and a little loading bar pops up at the bottom, but it stays at 0, it never exports the sequence. I was trying to export for FPP. I also included the audio and sequence file if you can find something wrong with that. If someone could export it to a .fseq and upload it here that would also be greatly appreciated. (I think something might be wrong with my vixen install, but no matter how many times I reinstall/uninstall, it never seems to fix it). https://github.com/BarrettGT/Christmas2021
Re: Vixen Will not export .tim to .fseq
Unfortunately, others will not be able to export a tim file without the rest of your profile. You need the whole profile to open and render the sequence file before it can be exported to FSEQ.
There's rarely a problem that an uninstall and reinstall will fix. That's not typically a logical first step in troubleshooting. (especially more than once)
How long did you wait on the progress bar? It usually starts pretty quick, but the progress can take a while if you've got a big complex sequence/profile.
I'd suggest that you look at the log files to see if there is anything logged with timestamps corresponding to when you export.
Do you have your controllers patched?
Ed
Happily retired
- You may not post replies
- You may not edit your posts
Forum Rules
