Results 1 to 9 of 9
Thread: FPP Sync
    113
    Default FPP Sync
    I finally have a good handle on how Players/remotes work in FPP. During testing things are working great and it's such a versatile system.
    I do have a question about how FPP would correct sync problem it finds. For example it 'remote A' was out of sync and behind the rest of the show, would it just skip ahead to regain sync?
    If this is the case, it seems it would be best practice to put the sound track on the master. It is the most common practice.
    We also have a video file that will play clips on a projection screen at various times in the show. We planned to put this on a dedicated FPP remote, but we also don't want the video skipping.
    Any suggestions in this regard?
    Thanks.
    5,629
    Default Re: FPP Sync
    Master keeps local sound and video in sync with local sequence. It also sends out sync packets that say "I am at millisecond xyz" when a remote receives that message it moves forward or back in the sequence to align with that message. It is critical that the sync message be delivered without any significant delay or jitter. In addition the remotes have a setting to say "Add/subtract this number of milliseconds from the time the master sent you". That can be used to configure out a consistent delay that may be added by your network.
    Dec 2020
    223
    How do you actually control a matrix? Do you upload files via the Falcon Player to a BBB and then send commands over Ethernet using something like an Falcon F48?
    113
    Thanks Martin. So the audio track (MyShow.wav) and the video track (MyShow.mp4) should both be on the master?
    that was my other question actually-- if the master (or remote I guess) can play two file simultaneously.
    5,629
    Quote Originally Posted by munu View Post
    Put FPP on the BBB and run it in remote mode. It will sync to the master.
    5,629
    I know the master plays multiple files at the same. I have to tried it on a slave so I cannot tell you if the slave can do this as well.
    113
    8,530
    Any FPP instance regardless of master or slave, can play one media file at a time, audio or video, but not both audio and video at once. There's no way to specify both at once in the playlist. So you only need the media file that particular FPP is going to use. And it can be mp3 on the master and mp4 on the slave.
    That's not to say that it can't output video and audio at the same time. It certainly can. But it has to come from the same file.
    113
    Thanks. Got it.
