Results 1 to 5 of 5
Thread: Arduino Uno usb servos controller
    Oct 2020
    Manilva (Málaga), Spain
    23
    Default Arduino Uno usb servos controller
    Hi, everybody. I want to do something like this: https://www.instructables.com/Intern...ic-Jack-OLant/
    I try to do a secuence with xligths, and use 4 servos. When i put the code into the arduino uno the servos all works at the same time, making crazy movements. The code y modified for this is this: https://pastebin.com/vM7i6Vyd What I´m doing wrong?
    5,739
    Default Re: Arduino Uno usb servos controller
    Two things that I've noticed on a quick scan:
    1) The const int NUM_SERVOS variable is set to '1'. This is used to set the size of the 'servos' array variable. I think that code later on in the sketch might be reading data from beyond the end of the servos array. Setting NUM_SERVOS to 4 might improve things.
    2) The end of the sketch outputs random values if serial data has not been received within the last second. I wonder if there is something wrong in the communications with XLights that is preventing the reception of appropriately formatted serial data and thus activating the random movement mode.
    Oct 2020
    23
    Hi Phil, I put now this code:
    Code:
      This code runs vixen through the arduino, usining pins 3, 5, and 6 with
      3 seperate servos; pins 9, 10, and 11 are used for 3 LED circuits with PWM;
      pins 12, 13 are extra digital pins.
      Adapted from code by GSRVAhiker17, zparticle, victor_pv, Si_champion, and Neil Tapp.
    #include <Servo.h>    // Servos
    #include <avr/wdt.h>  // Raw AVR watchdog timer
    // Testing mode (treat servos as simple PWM)
    const bool TESTINGMODE = false;
    // Vixen header (identifies a light sequence)
    const int HEADER_LEN = 2;
    const char seqHeader[] = {'~','!'};
    // Timeout waiting for serial input before going to random mode (in milliseconds).
    const int TIME_OUT = 1000;
    // Channels mapped to pin numbers
    const int BOLA1 = 9;
    const int BOLA2 = 10;
    const int BOLA3 = 11;
    const int BOLA4 = 12;
    const int LUCES1 = 3;
    const int LUCES2 = 5;
    const int LUCES3 = 6;
    const int LUCES4 = 7;
    // List of active channels
    const int channels[] = {BOLA1, BOLA2, BOLA3, BOLA4, LUCES1,LUCES2,LUCES3,LUCES4
    // Number of active channels
    const int NUM_ACTIVE_CHANNELS = 8;
    // PWM map
    const int isPWM[] = {true, true, true, true, true, true, true, true
    // Servos
    const int SERVO_DELAY = 15; // delay after servo is activated (allow it to move)
    const int NUM_SERVOS = 4;
    const int NEUTRAL = 120;  // Neutral position
    Servo servos[NUM_SERVOS];
    // Min servo opening in degrees from neutral position
    const int servoMin[] = {0, 0, 0, 0 };
    // Max servo opening in degrees from neutral position
    const int servoMax[] = {180, 180, 180, 180 };
    //const int servoMax[] = {20, 15, 15};
    // Servo channel map
    const int NO_SERVO = -1;
    const int servoNumber[] = {1, 2, 3, 0, NO_SERVO, NO_SERVO, NO_SERVO, NO_SERVO
    // Servo direction
    const int CLOCKWISE = 1;
    const int COUNTERCLOCKWISE = -1;
    const int servoDirection[] = {COUNTERCLOCKWISE, COUNTERCLOCKWISE, COUNTERCLOCKWISE };
    // Serial
    const long COM_SPEED = 115200;
    int incomingByte[NUM_ACTIVE_CHANNELS];  // array to store the channel values from the serial port
    // Misc
    int i = 0;                              // Loop counter
    int j = 0;                              // Loop counter
    volatile unsigned long  timer_a = 0;    // Timer
    //setup the pins/ inputs & outputs
    void setup()
      // enable the watchdog timer with a time of 1 second. If the board freezes, it will reset itself after 1 second.
      wdt_enable(WDTO_1S);
      // specifically for the UNO
      sei();
      // initalize PWM Channels / Pins
      for (i = 0; i < NUM_ACTIVE_CHANNELS; i++) {
        pinMode(channels[i], OUTPUT);
        if ((servoNumber[i] != NO_SERVO) && !TESTINGMODE) {
          servos[servoNumber[i]].attach(channels[i]);
      // set all the channels off to begin
        digitalWrite(channels[i], LOW);
          servos[servoNumber[i]].write(NEUTRAL);
      test_sequence(); // brief test
      Serial.begin(COM_SPEED);   // set up Serial
    void loop()
      if (Serial.available() >= NUM_ACTIVE_CHANNELS + HEADER_LEN) {
        wdt_reset(); // resets the watchdog (prevents board lockup)
        timer_a = millis ();  // Mark the time when a message was received
        // read the header to verify this is in fact a light sequence
        // probably overkill, but borrowing from the above sources...
        for (int i = 0; i < HEADER_LEN; i++) {
          if (seqHeader[i] != Serial.read()) { return; }
          //Serial.read();
        // read the oldest byte in the serial buffer:
        for (int i = 0; i < NUM_ACTIVE_CHANNELS; i++) {
          // read each byte
            // SERVOS ------------------------------
            int angle = map(incomingByte[i], 0, 255, servoMin[servoNumber[i]], servoMax[servoNumber[i]]);
            angle *= servoDirection[servoNumber[i]];
            servos[servoNumber[i]].write(NEUTRAL + angle);
            delay(SERVO_DELAY);
          } else if (isPWM[i]) {
            // PWM ---------------------------------
            analogWrite(channels[i], incomingByte[i]);
          } else {
            // DIGITAL (A2D) -----------------------
            if (incomingByte[i] <= 127) {
            } else {
              digitalWrite(channels[i], HIGH);
      } else {
        // Random mode starts if no serial input has been received in TIME_OUT milliseconds
        unsigned long diff = millis() - timer_a;
        if (diff >= TIME_OUT) {
          int random_a = 0;
            if ((servoNumber[i] != NO_SERVO) && !TESTINGMODE) continue;
            random_a = random(0, 2);
            if (random_a == 0) {
            } else {
    // Test the setup briefly
    void test_sequence() {
        delay (500);
    But also it doesn´t work. It moves one servo only on pin number 9. The other servos don´t continue the sequence. Also my problem was I do the sequence in xlights, and all my sequences was in vixen. Now I run with the vixen sequences but only take BOLA1 properly. BOLA2, BOLA3,BOLA4 don´t work. I don´t know were is the problem. Some help?? Thanks
    Cleethorpes, England
    99
    Hi Tripishadow
    this is the link that got me started a few years back and the code worked a treat and i still use it today
    https://www.youtube.com/watch?v=z0hRF4pyCD0
    This was my 1st attempt with vixen using the above code
    https://www.youtube.com/watch?v=QAtjPhybS8E
    Oct 2020
    23
    Hi. Everybody. I have solve the problem my self. The problem was the communication between vixen and the arduino. When I patch the element to the controller, it was color degrade or something like that, not was a direct line like the first one. When I put a direct line, parched both, it runs perfectly. Only the 4th servo don't work, but I will change the code to the one that shows @qble. I will tell you how it goes. Also I tried a led, and worked perfectly with the three servos.
    Thanks for all.
