Results 1 to 2 of 2
Thread: FPP won't save the time.
    Feb 2018
    1
    Default FPP won't save the time.
    I'm on Falcon version 4 using a 16 channel controller in Player/standalone mode. I'm connecting to the controller via ethernet. The controller has no internet connection at alI. I set the time in Settings to the year 2021. If I power off then power back on it resets to the year 2000. I don't care if the time is right as I want to play all the time. I just need to get it to a year that is within the range of the Scheduler. Help is appreciated. Thank you.
    5,630
    Default Re: FPP won't save the time.
    The PI does not have a real time clock. It needs either an RTC installed or internet access in order to automatically get the current time.
