Results 1 to 10 of 12
Thread: FPP and Falcon Picap + Rasberry Pi 3 B+ not working in Test mode
    5
    Default FPP and Falcon Picap + Rasberry Pi 3 B+ not working in Test mode
    Hello, I am a newbie user. I have connected my Falcon picap (attached to raspberry pi 3b+) to a string of ws2811 nodes powered by 12v supply through picap.
    I cannot get the lights to light up at all in the test mode. The strip is getting power (12v checked through multimeter) so the problem is definitely the data line. Is there anything I can do in the test mode to see if Falcon pi is sending out the data signal at the software level or there is data coming out of the Falcon picap board’s data line?
    I am essentially in troubleshooting mode and looking for ideas to determine if the picap is not working or Falcon pi player is not sending anything at all.
    G
    Jan 2010
    529
    Default Re: FPP and Falcon Picap + Rasberry Pi 3 B+ not working in Test mode
    A screenshot of your output configuration page on the pi would be helpful.
    5
    Here is the output configuration on the Pi. Since this is just testing, I have a string of WS2811 12v lights - 50 lights. Attachment 45152IMG_0391.jpg
    2,227
    doesn't look like the output config uploaded correctly.
    5
    2,227
    click the "enable string cape"?
    5
    Tried that. Does nothing :-(
    2,227
    It should be checked so make sure it carries a check.
    Config looks okay to me although I haven't used a piCap.
    Do you have any other inputs or outputs configured?
    Jan 2010
    529
    Be sure that when you check enable that you hit the save button
    Folsom, CA, USA
    2,413
    Quote Originally Posted by gassy View Post
    Then you will need to restart the FPPD
    In Lights Therapy
