Results 11 to 20 of 22
Thread: Pixels Staying Red
    Jan 2021
    201
    Default Re: Pixels Staying Red
    Okay so my first test was to unplug the PI from the end of the string since that was the easiest and now all 9 light up!!! Any ideas why the PI at the end could be causing that? I did make the cable myself so was thinking I somehow reversed polarity but I checked that and no issues.
    Could something actually be wrong with the last pixel where it won't pass the voltage? For now I just kept the PI at the end disconnected, if I go all white there is some flickering so I would definitely need that PI at some point, but luckily none of my sequences have full white so it shouldn't be a problem.
    Jan 2021
    495
    If I was in your shoes, I would just not use all-white, leave the PI open and move on to something else. I have AC's for all-white; if I want whites, I'll SSR that.
    Did you probe the PI leads with/ and without power with a voltmeter? How about swapping the power supply going into the other end? I've sometimes had power supplies fail to power and actually behave more like a load than a power. If your voltage actually dropped when you connect it, then I think you're seeing that. But it's after Thanksgiving, no time, maybe you just need to call it done.
    Jan 2021
    201
    Agreed this sounds like a January problem! haha
    This 12v PSU is brand new and dedicated for now to only that series of props but it does seem as if it's adding load and pulling power away from those 9 pixels. It's a Mean well too so wasn't even thinking it could be that. I haven't probed anything either but again for now I'll wait till January. But when I do how do I check them without power? Assuming I could just probe the PI wires lead with the PSU turned on and see if i'm getting ~12v. And then maybe only connect the PI line to the pixels at the end but not connect the data line at the beginning (pixel 1) to see if voltage is passing backwards through all of the pixels? Not sure that actually checks the whole setup with all 392 pixels though.
    Jan 2021
    495
    The PI leads will be one voltage with the PSU on and another with the PSU off. That's not too much work to probe, even in December. Switching PSU's is, though, especially if it's a 2nd-story bedroom window.
    There is an uncommon PI problem that Bill Porter only vaguely touched on in his pres (and never specifically said), where if you inject a little too much with different PSU's and their voltages are slightly different, it will actually cause a short. For example if your Meanwell is delivering 13.2V but your controller is providing 11.9V, but when your pixels are mostly off, the voltage never quite dips down to 11.9V by the time your meanwell current reaches back to the controller. That's why the rule of thumb is to isolate the VDD line coming from different PSU's. But that, too, is only a rule-of-thumb that can be broken, if you know your voltage drop best-case (actually worst-case this time) is sufficient.
    Jan 2021
    201
    This may be a dumb question, but wouldn't there be no voltage on the PI leads with the PSU off? Again my controller is on a separate PSU (PSU-1) so only V- and DI are going from my controller to the first pixel. I'm then injecting from my second PSU (PSU-2) at pixel 1 on the string and again at pixel 160. The PI lead with the issue is running to pixel 392 to inject. Would I be probing the exposed leads at pixel 392 or are you saying back at the PSU, or in this case I'm also using a distro block? or do i need to actually use the probe from the multi meter to pierce the cable casing itself? Sorry I've never really tested like this before.
    Actually, I just thought that I could possibly put a power injection tee on there and be able to check the voltage there when the PSU is on right?
    I did see somewhere the mention of two different PSU's voltage fighting against each other which is why I chose to just completely separate the two and only send V- and DI from the controller.
    I also thought about possibly moving my PI point to be ahead of the window in question, which would be at pixel 272. If that worked then it could be something with pixel 392 itself.
    Jan 2021
    201
    Doubling back here, I was finally able to test and there is 11.9 V coming through the PI line and 10 when the pixels are on. So it still doesn't seem to be the actual PI line or the PSU to me. I also moved my PI point to before my bedroom window outline and the same last 9 pixels were flickering and acting weird.
    I'm just going to replace those 9 pixels and set the lights up the same way to see if anything changes next year.
    thanks again,
    -Russ
    5,650
    Only replace 2. Last working and first flickering
    Jan 2021
    201
    So replace the first one of the 9 thatís are acting up and the one upstream of you will?
    I assumed that the first of the 9 was the culprit, so you replace the one upstream as a precaution in case that caused the failure in its neighbor?
  9. #19
    Mar 2020
    Post falls, Idaho, USA
    86
    Is it possible for you to change the order that the windows are hooked up. Place the offending one first and a known good window last. If those last nine pixels on the offending window work then the last nine on a good window don’t work. it’s an xlights configuration problem and if everything after the offending window doesn’t work then it’s a hardware issue.
  10. #20
    Jan 2021
    201
    Iíve gone through xlights and testing through fpp both my myself and with help from the xlights zoom people. Pretty certain itís not a software issue.
    Plus if I remove the PI at the end of the offending window the pixels work correctly.
