Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Dead esPixelStick?
    Nov 2021
    23
    Question Dead esPixelStick?
    I have been working on my pixel lights setting up the power supply and pixel stick in a waterproof box with fuse block etc. I was doing this with power supply unplugged. Before trying to hook up the lights to the power supply I turned everything on again. No lights, couldn't connect to the pixel sticks web browser. Went to reflash it, wouldn't communicate. Reset it with the reset button. No blue light anymore, even while trying to flash. The flash times out trying to recognize the chip. I'm selecting the USB com port. Is it truly dead? Am I missing something?
    7,439
    Default Re: Dead esPixelStick?
    Quote Originally Posted by JackOfManyMasterOfSome View Post
    Do you have an authentic EspixelStick or home brew ?
    Nov 2021
    23
    Authentic bought on Amazon.
    7,439
    did the onboard fuse blow ?
    Nov 2021
    23
    I checked that and the fuse looks good. What's even more weird is windows sees it when I plug it in to a USB port. I can see it in the devices list. I remove the board on the top when trying to flash it.
    7,439
    Can you see it in device manager ?
    7,439
    Try a different port and see if it is still recognized .
    Try a different usb cable .
    Pinch the usb and usb connection on board tightly during boot and flash.
    These connectors do not like to be manhandled and can get loose or even pop right out if looked at sideways .
    Nov 2021
    23
    I tried different USB ports, and the port number would change in the flash tool. It would still error out at the spot where it detects the chip.
    Connecting........_____....._____....._____.....__ ___....._____....._____....._____
    Traceback (most recent call last):
    File "bin/upload.py", line 19, in <module>
    esptool.main(sys.argv)
    File "G:/Programs/ESPixelStick_Firmware-3.2/ESPixelStick_Firmware-3.2/bin/esptool\esptool.py", line 2883, in main
    esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace)
    File "G:/Programs/ESPixelStick_Firmware-3.2/ESPixelStick_Firmware-3.2/bin/esptool\esptool.py", line 274, in detect_chip
    detect_port.connect(connect_mode)
    File "G:/Programs/ESPixelStick_Firmware-3.2/ESPixelStick_Firmware-3.2/bin/esptool\esptool.py", line 483, in connect
    raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
    esptool.FatalError: Failed to connect to Espressif device: Timed out waiting for packet header
    Done
    7,439
    Try grounding GPio 0 while loading firmware.
    Nov 2021
    23
    Do I just ground that to my power supply?
