Results 1 to 4 of 4
Thread: Hello All New to the site and Christmas lighting
    Nov 2021
    South Central PA
    4
    Default Hello All New to the site and Christmas lighting
    Hello all
    I am new to site and Christmas lighting. I have good knowledge with linux, home assistant, and WLED. I am start out with a new install for holiday lighting and projection shows. I want to blend the 2 together for a great viewing show.
    My question is has anyone developed a docker image to run FPP on an arm device? I see there is one for X86 but would like to run a docker on raspberry pi. I am not knowledgeable enough to build a docker image myself. With some help I would like to be able to do this.
    Thank you for reading
    Happy Thanksgiving to all!
    5,497
    Default Re: Hello All New to the site and Christmas lighting
    fpp runs nativly on the pi. there is no reason you cant make a docker image for it, but why?
    Nov 2021
    South Central PA
    4
    It would be easier to build/rebuild and test. I could run it on usb or ssd on my pi and take advantage of faster read write speeds. Guess if I want a docker for the pi I'm going to have to read up on building a docker container from scratch. I have never built my own docker container. I have always used others prebuilt dockers.
    5,497
    by definition an image running in a docker has slower reads writes and network access. it is too simple to use a pi to bother getting fpp into a docker
