Thread: ESPixelstick hangs on colorwash
    Oct 2012
    321
    Default ESPixelstick hangs on colorwash
    Running version 3.2, Xlights 2021.38, FPP 5.1.1
    While running a color wash sequence, it appears to hang, meaning that the only way to get it out of this mode is to power cycle it. Any other sequence appears to run fine. Anyone else come across this?
    2,167
    Default Re: ESPixelstick hangs on colorwash
    Wow that is an unusual problem. The ESPixelStick firmware would not know what the data represented. What is unusual about the color wash? Have you tried colorwash of various durations and color selections?
    Aug 2012
    Charleston, SC
    1,198
    That is very odd indeed. By hanging, what exactly happens? Do the pixels stay a certain color, can you access the web frontend, can you ping it, etc... Does this happen from both xLights and FPP, if not which source was being used?
    forkineye.com
    Aug 2012
    Charleston, SC
    1,198
    Also, what color is the wash? Does it go full white? What happens if you drop a white "on" effect? Could be a power drop.
    forkineye.com
    Oct 2012
    321
    Sorry on the delay answering...based on the fact that the device doesn't know or understand the data passing through it, and it works perfectly on other sequences, I'm going to go with it being a power droop that causes it to hang. I've kept the sequence so once the "season" is over, I will debug it further.
