Results 1 to 8 of 8
Thread: Falcon F16v3 Suddenly stopped light output in Test Mode
    Nov 2021
    6
    Default Falcon F16v3 Suddenly stopped light output in Test Mode
    I have a Falcon F15v3 that I have been using for a few months. I have been hooking up lights to it to test my soldering and such, and it was working fine earlier today. I setup a few lights, that I thought I had in the wrong order, as half lit, and the half after my join didn't. So I switched it, and then go no output at all.
    I'm only using port 1, and it's only a few pixels. I have rebooted the board several times, and now I've event factory reset it. I still get no light from the port. Have not tried other ports, but don't see anything indicating an error.
    Any help is greatly appreciated. If there are logs I can get somewhere, just let me know where and how, and I'll try to get them as well.
    EDOT
    I went and setup Port 2, and it is working... does a single port go out? Is it recoverable?
    Jan 2021
    317
    Default Re: Falcon F16v3 Suddenly stopped light output in Test Mode
    When I had that happen, it was because I thought I was only testing port 1, but in fact I was testing only port 16.
    Jan 2010
    522
    Fuse?
    Nov 2021
    6
    Question Re: Falcon F16v3 Suddenly stopped light output in Test Mode
    Quote Originally Posted by 1pet2_9 View Post
    Does it suddenly change for any reason? I've been using the same port for a while now, and it was working literally minutes earlier.
    Nov 2021
    6
    Quote Originally Posted by gassy View Post
    Fuse?
    Are there fuses per port? If so, where? It very well could be I suppose.
    Nov 2021
    6
    Nevermind, yes, there are fuses for each port. I'm a blind fool sometimes.
    I pulled fuse 1, and inspected. I believe it's fine based on
    1. It had the little green light (i think it's green) next to it shining, and
    2. Visually it's blackened a bit, but intact.
    I went ahead and switched it with the fuse from 16 (never used 16 to date).
    Still no joy.
    Nov 2021
    6
    I have also switched my pigtail from port 2 to port 1, to ensure it's not a wiring issue. Still no luck.
    Nov 2021
    6
    To verity, I have just been leaving all ports enabled for testing. 2 is still working, but 1 won't.
