Results 1 to 8 of 8
Thread: Wired DMX to E1.31 Bridge?
    Oct 2009
    Vancouver BC
    87
    Default Wired DMX to E1.31 Bridge?
    I know there are lots of ways to convert E1.31 to wired DMX ( ESPixelStick firmware supports this) but I have a need to go from a legacy wired DMX output (no option to send E1.31 natively) to E1.31.
    I only need to support a single DMX universe.
    Has anyone seen such a device (various web searches haven`t turned up anything) or related code for DIY?
    8,530
    Default Re: Wired DMX to E1.31 Bridge?
    Not exactly DIY priced, but here's one option https://www.enttec.com/product/contr...dmx-interface/
    Oct 2009
    Vancouver BC
    87
    Thanks for finding that..
    It is a bit pricey...
    Some of the DMX adapters have become very constrained due to supply chain issues...
    I have been looking for some of these:
    http://dmxking.com/usbdmx/ultradmxmicro
    Can`t find anywhere that has them in stock and the manufacturer doesn`t expect to make any more till 2022
    5,661
    Been searching. Here is the answer to your first part: DMX into an Arduino: https://sourceforge.net/p/dmxlibrary...i/DMX%20Slave/
    Still looking at Data to E1/31 out
    5,661
    And here is a lib that can be used to output E1.31 data
    https://github.com/tigoe/sACNSource
    UK S80 postcode
    1,572
    Hi, that is a bit of an obscure request. The problem is that DMX has a slow transmission speed compared to E1.31 or WS281x pixel data. Can you tell us a little more about what you are wanting to achieve and whilst you state ‘a single universe’ how many channels and where are the in the universe i.e. 20 channels 1 to 20 or all 512.
    Oct 2009
    Vancouver BC
    87
    It is a bit of an obscure request. In this case a friend has some PC`s running various VSA (Visual Show Automation) sequences using wired DMX (VSA only supports wired DMX and various USB connected controllers). While he does have various wired DMX controllers (dimmers and servo controllers) he would like to make use of some E1.31 controllers that he also has.
    I know there is a channel limitation with a single DMX universe (he doesn`t need to control that many pixels)
    I know he could import the VSA sequences into xLights and use that (this suggestion has been made)
    Ideally he needs a box that listens to a wired DMX connection and resends it out via E1.31 (just the single universe)..
    It`s not a huge deal (so they are not really wanting to through $$ into it).
    I was just wondering (hoping) if such code already existed..
    Jul 2012
    Novi, MI
    453
    I was thinking about the original post. Why not just run another parallel DMX output from E131 to whatever downstream needs it. To minimize wired DMX runs, I used to have DMX bridges scattered throughout the display, all outputting the same universe.
