Thread: Projector mapping and communicating with FPP
    Feb 2019
    2
    Default Projector mapping and communicating with FPP
    Hi all. I'm about 6 ours into searching here and in Falcon Christmas and can't seem to find the answer. I want to add projector mapping. I found many softwares but one called mapmap is free and seems user friendly. Once I map the house how do I create the videos and get them to integrate / play with FPP. The plan is to have the FPP connected to the projector through hdmi. This is all new to me so thanks in advance for any help.
    7,636
    Default Re: Projector mapping and communicating with FPP
    You are on the right track . Map your intended target -> import your map to video editing software and apply your effects etc then save and export .
    You may need to consider video length and FPS/rate when exporting to suit your sequence fps/timing .
    I like to use Vegas Pro for creating and editing videos.
    You also may need to export a specific file format for your purpose.
    5,881
    +1 Vegas Pro - Good Software.
    Feb 2019
    2
    You also may need to export a specific file format for your purpose.[/QUOTE]
    Thank you. Will the video have to be run through xlights or will I be able to upload the video directly into FPP content and Playlist. Also Does it need to be in any specific format to play properly in FPP?
    Sep 2007
    Orlando
    59
    I used Heavy M to create the videos, saved them in mp4 format and then use FPP to play it.
