Results 11 to 20 of 23
Thread: Master/remote setup
    Chambersburg, PA
    1,053
    Default Re: Master/remote setup
    FWIW, I am using 9 RPi's (3B+ and Zero) all with capes/hats in a Master/Remote wireless configuration. My Master is driving my MegaTree 12x61, Three Layer Star (88), and 1 Renard 32 controller, as well as my audio and my show network AP. So yes, you can drive a controller with your FPP Master.
    2016 - No Display
    3,186
    I don't know why, but I have this urge to tell about some of our setup here... (sorry)
    master FPP is providing audio to the transmitter, sending E1.31 to 4-E682, 4-Falcon F16 (blue, version 2, version 3), 1-Kulp K32, and a couple Falcon F4s.
    On top of that it is sending sync to 4 more F4s with Rpi based FPPs across the lake (via a Ubiquiti M5 network).
    So you see, one FPP instance can do a lot and not even burp.
    95
    my master sends data to two f16s. the master also has a dac+ pro hat for audio.
    To confirm, your master sends out e131 data or sync packets?
    5,435
    Quote Originally Posted by spaulgal View Post
    My master sends out E1.31 data AND FPP Sync packets.
    Martin
    95
    Martin... each of your F16's also have local PIs driving them?
    5,435
    Mostly, yes. The master drives two F16s. I am really looking forward to the day when the F16s have built in SD cards but my V3 and lower controllers are kind of SOL. I have a 5 port cheap switch + FPP + Controller in each controller box. They are connected in a (mostly) star configuration back to the master FPP. This limits heavy traffic to go between the local FPP and the local controller with only the sync messages traversing the entire network.
    3,186
    Curious - wired or wireless between your master and the F16/switch/FPP controller boxes?
    5,435
    My show network is 99% wired. The switch co-located with the master has a dual radio AP connected to it. One radio connects to my home network as a STA. The other radio runs in AP mode allowing me to connect distant FPP instances and my tablet. My Tune to sign is on the other side of my driveway, I use WiFi to keep it in sync with the show. Because the E1.31 traffic is local, the WiFi is pretty much empty (aka low congestion = low latency). The tune to sign also has an FPP (this year it will be an ESP) that uses the FPP Sync to stay in sync with the show.
    3,186
    Thanks.
    I just finished this year's setup. Wired from a master to 11 controllers (listed above) around the primary display/show area.
    Using a Ubiquiti M5 system as a multi-point bridge tied to the master switch to get across the lake where 4 more are waiting.
    All the "local" units run full E1.31 from the master. So does the audio. The master also puts out sync to go across to the other side where Rpis are running as remotes driving the 4 controllers on that side.
    One curious thing is that for some reason I have placed an Rpi, with wifi antennas, at each of the different "groupings" in the display/show area. They are turned off, but are waiting for me to pull the trigger on multiple "groups" using sync to keep them in step. Thing is the wired network around the show works great feeding all the controllers, so I'm very hesitant to switch to synced remotes. I've done it in the past, and had about 90% success. A Ubiquiti pico-station (2.4GHz) is also setup, but off. They are in place in case the wire gets cut/chewed/run over/sold for copper scrap. I can get the show back up in a very short time. Just can't get past my mantra of "if it don't move and is accessible, wire it."
    5,435
    Thanks.
    Not sure why you equate using sync with wireless. I use sync on my wired network with good success. Turn those PIs on and keep the WiFi turned off. Make them remotes and tell your master to stop sending E131 data to the controllers near the remotes (uncheck the active box). If it gives you issues, then you can easily revert (checking the active box and saving.
