Thread: RGB Options for Leaping Arches
    Sep 2017
    33
    Default RGB Options for Leaping Arches
    I was looking to use the Holiday Coro rgb leaping arch package but was told by Holiday Coro that to use the kit, I would need to use XLights to sequence to then run on my Pi via Falcon. The issue is that I have been using Vixen to sequence and do not want to have to rebuild my sequences from scratch in XLights. Anybody have suggestions as to preassembled rgb kits that will sequence on Vixen and then run via Falcon on Pi3?
    1,990
    Default Re: RGB Options for Leaping Arches
    FUD (fear, uncertainty, doubt) and ignorance from HC on this one. Vixen and xLights are functionally equivalent programs. They both work. Were they trying to sell you sequences already done?
    You can buy their arch hardware and sequence just fine in Vixen. Oh look, there is even an arch element in Vixen. Wonder if that would work for leaping arches!?
    People that work in this industry really should get educated about the industry. Looking at you HC.
    Sep 2017
    33
    No they didn't try to upsell anything but I was confused as they list Vixen as being compatible and then told me I should use xlights. I assumed since the pi has an ethernet port and their controller ran off cat5 that it would work but wanted to ask before pulling the trigger.
