Results 1 to 7 of 7
Thread: Vixen and Mega Tree
    Mar 2017
    Clinton Twp. Michigan
    111
    Default Vixen and Mega Tree
    Last year I made a Mega Tree with 10 strings and I am adding 6 more strings this year for a total of 16. Can I just add 6 more strings in Vixen or do I need to delete last years tree and state a new tree? If I can just add to the old tree can you tell me how.
    AJVenti
    5,264
    Default Re: Vixen and Mega Tree
    WARNING: DO NOT DELETE YOUR ORIGINAL DEFINITION, YOU WILL LOSE ALL OF THE EFFECTS APPLIED TO THE TREE.
    Add 6 additional legs to the tree, update the preview screen. Adjust the effects to include the new legs.
    Mar 2017
    111
    I added 6 additional legs to the tree preview screen. Now how do I add them in Setup Display.
    5,264
    If you did not add them in setup display, what did you bind them to in the preview screen? If you created new elements in the preview screen then you need to add those new elements to the existing elements in the setup screen.
    Maryville, Illinois
    1,973
    You can do it all in the preview except the final patching. You can add elements in the preview just like you can in the Display Setup. The same functions are there. So add the extra elements by using the right click menu. Then up the count of strings on the tree in the property panel when the tree is selected and then link the new preview strings to the new elements in the property panel as well.
    Only thing you will need to do in Display setup is configure the color handling and do the patching to your controller.
    Mar 2017
    111
    I have tried adding to the tree in the property panel it shows the additional strings but the do not show in the display setup. What am I doing wrong?
    Oct 2019
    University Place. WA
    206
    Display setup is where you should start first. Add the additional strings and color handing, and patch the addresses. Then you should be able to add to the setup preview. If you have already drawn the extra strings, then click on one and then select the Collection line. Click on the dots to bring up the linked elements page. If nothing is selected or the wrong thing is there, drag the correct one from the left list to that element. Don't forget to save and update when you exit.
    Love LEDs!
