Thread: Thanks to MartinMueller2003 Unicast for ESP !!!!!
    7,340
    Default Thanks to MartinMueller2003 Unicast for ESP !!!!!
    The title says it .
    After a lot of experimenting I have come to conclude that Unicast is absolutely best use .
    By using this method there is 0 dropouts connection wise and 0 effect on other devices , especially if they have relays . With multicast I discovered many issues .
    Martin inadvertently put the Unicast bug in my ear by stating its definition was not a requirement .
    Even though this is set in firmware ->
    if (e131.begin(E131_MULTICAST, UNIVERSE, UNIVERSE_COUNT)); // Listen via Multicast
    Martin was right on the $$$$ .
    Unicast ignores this firmware setting.
    Thank you much for that Martin .
    5,285
    Default Re: Thanks to MartinMueller2003 Unicast for ESP !!!!!
    Your Welcome?
    FYI: I would use FPP Remote player mode instead of E1.31. Then the entire load on the WiFi pretty much goes away.
    7,340
    I do agree with FPP for larger scale usage, though that is learning curve yet needed .
    This is just a small scale setup . Have been testing wireless AC with pixel data and noticed issues affecting other controllers
    with relays on board and wifi dropout in multicast . Unicast seems to have cleared this up ..
    However I am thinking simple AP Web Server may be better suited in this case .
