Thread: Wemos ADC Operation
    5,628
    Default Wemos ADC Operation
    I'm under the impression that, like most microcontrollers with ADCs, the ESP CPU writes to a hardware register to start an ADC conversion. The ADC conversion finishes some time later, and the 8266 system function system_adc_read blocks during this time interval. I've read somewhere that them maximum conversion rate is on the order of 100 Kps, which would put the system dead-time of about 10uS while the conversion is in progress. How accurate is this understanding? Is there some way for an application (sketch/library) to return immediately after starting the conversion and be interrupted later when the result is available (other than by using a timer interrupt)?
    Jan 2021
    130
    Default Re: Wemos ADC Operation
    I found this for Arduino (looks like a Mega to me):
    void setup(){
    Serial.begin(115200);
    adcAttachPin(35);
    adcAttachPin(25);
    void loop(){
    //start 1 pin for each ADC bus
    adcStart(35);
    adcStart(25);
    //you can check adcBusy(pin), but adcEnd will wait anyway
    uint16_t a0 = adcEnd(35);
    uint16_t a1 = adcEnd(25);
    Serial.printf("ADC: %u, %u\n", a0, a1);
    But I cannot vouch for how that works exactly with Wemos.
    5,628
    Thanks, I'll try that out.
