Results 1 to 10 of 17
Thread: Wemos ADC Operation
    5,853
    Default Wemos ADC Operation
    I'm under the impression that, like most microcontrollers with ADCs, the ESP CPU writes to a hardware register to start an ADC conversion. The ADC conversion finishes some time later, and the 8266 system function system_adc_read blocks during this time interval. I've read somewhere that them maximum conversion rate is on the order of 100 Kps, which would put the system dead-time of about 10uS while the conversion is in progress. How accurate is this understanding? Is there some way for an application (sketch/library) to return immediately after starting the conversion and be interrupted later when the result is available (other than by using a timer interrupt)?
    Jan 2021
    645
    Default Re: Wemos ADC Operation
    I found this for Arduino (looks like a Mega to me):
    void setup(){
    Serial.begin(115200);
    adcAttachPin(35);
    adcAttachPin(25);
    void loop(){
    //start 1 pin for each ADC bus
    adcStart(35);
    adcStart(25);
    //you can check adcBusy(pin), but adcEnd will wait anyway
    uint16_t a0 = adcEnd(35);
    uint16_t a1 = adcEnd(25);
    Serial.printf("ADC: %u, %u\n", a0, a1);
    But I cannot vouch for how that works exactly with Wemos.
    5,853
    Thanks, I'll try that out.
    5,853
    Something seems to be wrong or missing - those three adc functions are all marked as 'not found in this scope' when compiling with the Arduino IDE. They are mentioned lots of times on the web in the context of the ESP32, but the first few google pages don't return any hits wrt the 8266. Perhaps I'm missing some include file.
    5,874
    Did you read this page? The syntax is different than you were using. I used this as a reference for one of my projects.
    https://docs.espressif.com/projects/...erals/adc.html
    5,853
    Unfortunately, I don't have the 8266 RTOS development software installed. I do assume, however, that the calls to adc_read are non-blocking, so that would be useful.
    7,636
    Giving this a shake for updates
    5,853
    I've got all of the parts, just have to get to it. I've got too many half-finished projects in the works, including my first 3D printer arriving tomorrow.
    9,520
    Quote Originally Posted by P. Short View Post
    Uh-oh.... now you're doomed... all of your spare time will be used up by that printer...
    http://digwdf.org/store/
    Even though the DIGWDF Store has been closed for almost three years, it's still awesome!
    Jun 2015
    96
    The ESP8266 ADC is useless for me, it only accept 0-1v and noisy, using voltage divider knocking down to that level and not enough scaling. I use ADS1115 when I need ADC on the ESP8266.
