Results 1 to 10 of 22
Thread: Matrix Serial Read
    Mar 2015
    Kent, WA
    29
    Angry Matrix Serial Read
    have this code I have tried to make serial read
    Code:
    // You must download and install the library from http://fastled.io/
    #include <FastLED.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_NeoMatrix.h>
    #include <Adafruit_NeoPixel.h>
    #ifndef PSTR
    #define PSTR // Make Arduino Due happy
    #endif
    #define NUM_STRIPS 44                             // Changed from original for 3 strings
    #define NUM_LEDS_PER_STRIP 22                    // Using 63 pixels per string
    #define NUM_LEDS NUM_LEDS_PER_STRIP * NUM_STRIPS // Total number of LEDs
    #define PIN 8
    CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
    Adafruit_NeoMatrix matrix1 = Adafruit_NeoMatrix(NUM_STRIPS, NUM_LEDS_PER_STRIP, PIN,
                                 NEO_MATRIX_TOP     + NEO_MATRIX_LEFT +
                                 NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
                                 NEO_GRB            + NEO_KHZ800);
    const uint16_t colors[] = {
        matrix1.Color(255, 0, 0), matrix1.Color(0, 255, 0), matrix1.Color(255, 255, 0), matrix1.Color(0, 0, 255), matrix1.Color(255, 0, 255), matrix1.Color(0, 255, 255), matrix1.Color(255, 255, 255)
    void setup() {
      // Define the speed of the serial port
      Serial.begin(115200);
        matrix1.begin();
      matrix1.setTextWrap(false);
    void loop() {
      // Set some counter / temporary storage variables
      int cnt;
      unsigned int num_leds;
      unsigned int d1, d2, d3;
      // Begin an endless loop to receive and process serial data
      for (;;) {
        // Set a counter to 0. This couter keeps track of the pixel colors received.
        cnt = 0;
        //Begin waiting for the header to be received on the serial bus
        //1st character
        while (!Serial.available());
        if (Serial.read() != '>') {
          continue;
        //second character
          continue;
        //get the first digit from the serial bus for the number of pixels to be used
        d1 = Serial.read();
        //get the second digit from the serial bus for the number of pixels to be used
        d2 = Serial.read();
        //get the third digit from the serial bus for the number of pixels to be used
        d3 = Serial.read();
        //get the end of the header
        if (Serial.read() != '<') {
          continue;
          continue;
        // calculate the number of pixels based on the characters provided in the header digits
        num_leds = (d1 - '0') * 100 + (d2 - '0') * 10 + (d3 - '0');
        // ensure the number of pixels does not exceed the number allowed
        if (num_leds > NUM_LEDS) {
          continue;
        /*  ----have commeted this section to try and use matrix only----
            // CODE ADDED - tell FastLED there's 63 PIXEL leds on pin 8, starting at index 0 in the led array
            //this line change for one long string
            FastLED.addLeds<WS2811, 8, RGB>(leds, 0, NUM_LEDS_PER_STRIP);
            // CODE ADDED - tell FastLED there's 63 PIXEL leds on pin 9, starting at index 64 in the led array
            FastLED.addLeds<WS2811, 9, RGB>(leds, NUM_LEDS_PER_STRIP, NUM_LEDS_PER_STRIP);
            // CODE ADDED - tell FastLED there's 63 PIXEL leds on pin 10, starting at index 127 in the led array
            FastLED.addLeds<WS2811, 10, RGB>(leds, NUM_LEDS_PER_STRIP * 2, NUM_LEDS_PER_STRIP);
            // CODE ADDED - tell FastLED there's 63 PIXEL leds on pin 11, starting at index 190 in the led array
            FastLED.addLeds<WS2811, 11, RGB>(leds, NUM_LEDS_PER_STRIP * 3, NUM_LEDS_PER_STRIP);
            // FastLED.addLeds<WS2811, 8,RGB>(leds, 0, 256);
        do {
          leds[cnt].r = Serial.read();
          leds[cnt].g = Serial.read();
          leds[cnt++].b = Serial.read();
        while (--num_leds);   // Tell the FastLED Library it is time to update the strip of pixels
    //    FastLED.show();       // WOO HOO... We are all done and are ready to start over again!
        matrix.show(); //hopefully will display
    from, this code
    Code:
    #define PIN 12
    // MATRIX DECLARATION:
    // Parameter 1 = width of NeoPixel matrix
    // Parameter 2 = height of matrix
    // Parameter 3 = pin number (most are valid)
    // Parameter 4 = matrix layout flags, add together as needed:
    //   NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
    //     Position of the FIRST LED in the matrix; pick two, e.g.
    //     NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
    //   NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
    //     rows or in vertical columns, respectively; pick one or the other.
    //   NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
    //     in the same order, or alternate lines reverse direction; pick one.
    //   See example below for these values in action.
    // Parameter 5 = pixel type flags, add together as needed:
    //   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
    //   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
    //   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
    //   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
    Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, PIN,
      NEO_MATRIX_BOTTOM    + NEO_MATRIX_RIGHT +
      matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(255, 255, 0),matrix.Color(0, 0, 255), matrix.Color(255, 0, 255), matrix.Color(0, 255, 255), matrix.Color(255, 255, 255)};
    void setup() {
      matrix.begin();
      matrix.setTextWrap(false);
      matrix.setBrightness(5);
      matrix.setTextColor(colors[0]);
    int x    = matrix.width();
    int pass = 0;
    void loop() {
      matrix.fillScreen(0);
      matrix.setCursor(x, 0);
      matrix.print(F("Test"));
      if(--x < -30)
        x = matrix.width();
        if(++pass >= 8) pass = 0;
        matrix.setTextColor(colors[pass]);
      matrix.show();
      delay(30);
    I just can't figure out the serial read, :mad:
    I am going to try and make it for 2 matrices.
    I have been trying to research this guess I am not finding the right resources.
    I do work about 60 hrs a week with no access to a computer to be able to find this information so any and ALL help will be appreciated.
    1,940
    Default Re: Matrix Serial Read
    @angus40 answered in a different thread. It does appear you mixed in FastLed with the NeoMatrix code. There is a FastLed Matrix but the examples don't look like what you have. When you tested by changing the example code...did your matrix work? Start by getting a matrix to work, then you just need to add in the serial input to set the colors of the matrix. Then you need to figure out how to do that. Some of the NeoMatrix code appears to be doing lots of translation...maybe a fastled example would be a better starting point. But even those seem like they have been adapted for doing the matrix from within the sketch. I didn't really see one that was setting each value...
    Since you are driving the matrix from Vixen, why are messing with matrix code on the arduino? Just for fun? Then okay. But, you can define the matrix in Vixen and just send data - which I think you you already know about as I think you posted working code for ws2811.
    Mar 2015
    Kent, WA
    29
    For some reason my arduino max will not control more than 900 pixels thought matrix might make them both work since 1224 pixels. Lowered baud rate and same thing maybe have to use different board.
    1,940
    did one of the example sketches work for controlling the matrix?
    Mar 2015
    Kent, WA
    29
    So far I have had to use the norm sorting sketch and then manually hange the elements. First string normal the following reverse the n normal and so on
    Seemsto work just was looking for a something that was easier as I want to add a couple more matrix and have faces argue. During Halloween.
    Mar 2015
    Kent, WA
    29
    Question Re: Matrix Serial Read
    ok so i have given up on trying to make serial read matrix just adjusted the elements to make it work,
    one grid is 44x22 and works with this code
    Code:
    //must put >>968<< as header.  and will have to zig_zag rows manually in vixen.
    //#include <Adafruit_GFX.h>
    //#include <Adafruit_NeoMatrix.h>
    //#include <Adafruit_NeoPixel.h>
    #ifndef PSTR
    #endif
    //#define NUM_STRIPS 44 // made 44 for colums Changed from original for 3 strings
    //#define NUM_LEDS_PER_STRIP 22 // now 22 per string -- Using 63 pixels per string
    #define NUM_LEDS 968
    CRGB leds[968];
    void setup() {
      Serial.begin(115200);// now 115200 to see if not too fast for amount of leds 230400 work for a minute then stopped
    void loop() {
      int cnt;
      for (;;) {
        cnt = 0;
        //1st character
          continue;
        //second character
          continue;
        d1 = Serial.read();
        d2 = Serial.read();
        d3 = Serial.read();
          continue;
          continue;
          continue;
        // CODE ADDED - tell FastLED there's 50 PIXEL leds on pin 8, starting at index 0 in the led array
        //FastLED.addLeds<WS2811, 8,RGB>(leds, 0, NUM_LEDS_PER_STRIP);
        // CODE ADDED - tell FastLED there's 50 PIXEL leds on pin 9, starting at index 63 in the led array
        //FastLED.addLeds<WS2811, 9,RGB>(leds, NUM_LEDS_PER_STRIP, NUM_LEDS_PER_STRIP);
        // CODE ADDED - tell FastLED there's 50 PIXEL leds on pin 10, starting at index 126 in the led array
        //FastLED.addLeds<WS2811, 10,RGB>(leds, NUM_LEDS_PER_STRIP*2, NUM_LEDS_PER_STRIP);
        // CODE ADDED - tell FastLED there's 50 PIXEL leds on pin 11, starting at index 189 in the led array
        //FastLED.addLeds<WS2811, 11,RGB>(leds, NUM_LEDS_PER_STRIP*3, NUM_LEDS_PER_STRIP);
        // HOPEFULLY THIS WILL WORK FOR THE GRID
        //    FastLED.addLeds<WS2812B, 2, GRB>(leds, 0, 256);
        FastLED.addLeds<WS2812B, 8, GRB>(leds, 0, 968); /* when extra -- NUM_LEDS_PER_STRIP*4-- */
        // Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, 12,
        //  NEO_MATRIX_TOP     + NEO_MATRIX_LEFT +
        //  NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
        //  NEO_GRB            + NEO_KHZ800);
        do {
        while (--num_leds);
        FastLED.show();
        //    matrix.show();
    when I change it to to add the 256 (32x80) grid like this
    Code:
    //must put >>1224<< as header.  and will have to zig_zag rows manually in vixen.
    #ifndef PSTR
    #endif
    #define NUM_LEDS 1224
    CRGB leds[1224];
    void setup() {
    void loop() {
      int cnt;
      for (;;) {
        cnt = 0;
        //1st character
          continue;
        //second character
          continue;
        d1 = Serial.read();
        d2 = Serial.read();
        d3 = Serial.read();
          continue;
          continue;
          continue;
        do {
        while (--num_leds);
        FastLED.show();
        //    matrix.show();
    wonder if any one might know what is wrong as i have ready on multiple places that mega can handle 2500 pixels
    7,259
    This may not be your primary issue but I am curious here .
    This accounts for pixels in your code .
    CRGB leds[968];
    Why is this in your code ->
    to satisfy this ?
    continue;
    should it be this ?
    if (num_leds > leds[]) {
    continue;
    Mar 2015
    Kent, WA
    29
    The second code was not updated correctly the two lines should show, guess I copied the wrong one
    FastLED.addLeds<WS2812B, 8, GRB>(leds, 0, 968) // for the first 44 x 22 matrix
    FastLED.addLeds<WS2812B, 10, GRB>(leds, 968, 256) // for the second 32 x 8 matrix
    This worked fine for the other 63 pixel strands. 4 other on 4 different pins
    7,259
    Quote Originally Posted by skykicker View Post
    To word properly, for each instantiation you need to add ->
    FastLED.addLeds<WS2812B, 10, GRB>(leds1, 968, 256) // for the second 32 x 8 matrix
    CRGB leds[968];
    CRGB leds1[xxx];
    Mar 2015
    Kent, WA
    29
    Thanks I will give that a shot when I get a chance.
