Results 1 to 10 of 14
Thread: Vixen 3.8 released
    8,290
    Default Vixen 3.8 released
    Vixen 3.8 has been released.
    This version has a number of small improvements to existing effects as well as adding a new Chevron effect. A number of bugs were also fixed and the core behind the scenes libraries have been updated.
    This version may not seem like a lot, but we've also been working hard on some other functionality behind the scenes. Namely support for Moving Heads (aka DMX fixtures). We didn't feel that those features have been tested thoroughly enough yet to include in the release, but we're getting close. You can expect those features to be in the upcoming dev builds and may even make it into the minor version releases yet this year. Stay tuned for some exciting news about moving heads in the near future.
    Here's the release notes for the 3.8 release.
    Improvement
    [VIX-2944] - Allow users to animate Morph effect shapes that enter and exit the display element
    [VIX-3033] - Add rotation to the Bars Effect
    [VIX-3045] - Add Gilbert Engineering to Vendor Browser
    [VIX-3053] - Add "Center Stop" to Picture Effect
    [VIX-3064] - Update OpenTK to the latest version (4.6.3)
    [VIX-3065] - Update core dependencies for the next release track.
    New Feature
    [VIX-2963] - Create Chevron Pixel Effect
    Bug
    [VIX-3051] - Bars Effect (Flat) Highlighting does not work with 3D when using Moves Left or Right
    [VIX-3052] - Morph Wipe is not lighting the top ring of pixels on one of my pixel trees
    [VIX-3071] - Vendor model browser can fail if item does not have an id.
    [VIX-3072] - Specialty sound devices can cause bad behavior.
    [VIX-3077] - Bars Effect is not initializing RotationAngle for existing sequences
    [VIX-3078] - Crash in Curve editor when inputting a period in the value text field.
    Aug 2013
    Surprise, Az
    678
    Default Re: Vixen 3.8 released
    Awesome! Thanks guys!
    Aug 2013
    Surprise, Az
    678
    So I feel kinda dumb... where is the chevron effect? I don't see it on the effects menu.
    Edit: I'm guessing I found it under bars...zig-zag. Very cool effect
    8,290
    Quote Originally Posted by Popo-B-Trippin View Post
    Yep. Sorry about that confusion. Initially it was going to be its own effect, and that's how the ticket was written and flowed thru to the release notes. But the more we got into it, the more it felt like it was a better fit as an enhancement to the bars effect.
    Kenai, Alaska
    145
    Thanks to everyone involved for keeping this a great piece of software.
    Mar 2017
    Indiana
    195
    To all the folks who made this possible, THANK YOU!!
    204
    Thank-you all for the work you do.
    Mar 2015
    Kent, WA
    29
    Thanks guys for the new verson. It looks great.
    For some reason now none of my arduinos work with vixen, after update, always have great pride in saying that i use vixen to controll the lights.
    i have 3 arduino mega's
    first one controlls 32 ssr soon to be 40,
    the second controlls 4 stings of 63 nodes
    the third runs the 2 matrix. only had one was trying for a second, even if i had to manually change the setup so they match.
    however out of some flook or maybe because of a windows update Vixen is no longer sending the serial code to the arduino's. I am away from my computer at the moment to upload the code's have.
    maybe i need to change some in that. or maybe now need to include something extra for Vixen.
    I would love to continue to use vixen, as all the sequences are in there, plus is a ton easier to understand how to set up verses the others.
    or do i have to switch to raspberry pi to now run the displays where i have no idea where to start on that.
    1,943
    You should be fine. Arduinos via serial are very easy to setup. When you have a chance, show us the configs and what ports you have set on your computer.
    8,290
    There were no updates related to the serial output module in this version. (For several years now). Have you done all of the basic serial output troubleshooting? Are you sure your dongles were connected when you started vixen? Have you verified that your output modules still have the correct com ports selected? Are the vixen outputs enabled?
