Results 11 to 20 of 23
Thread: Vixen 3.8 released
    Mar 2015
    Kent, WA
    29
    Default Re: Vixen 3.8 released
    Sorry accidently wrong forum
    8,310
    You should start a new thread for your arduino issues. That doesn't belong in an announcement thread. Vixen team doesn't do arduino development. That's not our specialty. We do Vixen, not hardware. Your arduino sketch development and troubleshooting probably belongs in the arduino category.
    One thing that sticks out is that your 3 sketches use 3 different baud rates. You only show one of the controller configs which is set to 115200 on com5. So that would hopefully be for the second sketch you posted.
    And another thing i can confirm from your screenshots is that none of your output modules are disabled. If they were, they'd have a red ball in front of them.
    The most common problems with serial based control, especially when using multiple ports, is that the devices are either not available when vixen tries to begin using them, or if the com port numbers change on the fly. When you're using multiple of the same type of device, windows has no way of knowing which is which. They all look identical to windows. So the com port numbering can vary every time you fire them up. Windows just assigns them in order as it discovers them. I've heard of guys who use power sequencing circuits that will power up USB serial devices one at a time in a specific order to help ensure that the port numbers come up the same way every time.
    Nov 2018
    Fairfax, Virginia
    85
    My 3.8 seems to freeze when I click on edit preview. Could this be a computing power problem or is this a program problem?
    8,310
    Quote Originally Posted by patmitchell View Post
    That could go either way. Did it happen after recent changes to your profile, or is your profile the same as it used to be? Does it just sit there frozen or does it eventually crash? In any case, if it's reproducable, we'd like to dig into it further. If you could upload a copy of the profile (slimmed down without sequences or audio) to a google drive or similar and start a ticket on bugs.vixenlights.com, we'll take a look at it and see if we can figure it out.
    Sep 2012
    Marble Falls Texas
    35
    Where is the import option for importing Vixen 2.x sequences? All i see are options for importing vixen 3 packages. Have read that you could do it in previous releases.
    Sep 2012
    Marble Falls Texas
    35
    Quote Originally Posted by Christmas Mark View Post
    Never mind, sometimes I overthink things, still trying to figure Vixen 3 out.
    May 2013
    87
    Hi all, vixen crash after loading a music, any idea why is doing that.
    1,990
    Quote Originally Posted by waites View Post
    This release 3.8 build 1045? or some other?
    Does it sound like this?
    https://vixenlights.atlassian.net/browse/VIX-3030
  9. #19
    Kansas City Missouri
    2,773
    Could be corrupt file. Open the music file and re-save it.
  10. #20
    Maryville, Illinois
    1,980
    I would make sure your sound device is active and available when you start Vixen. That is one of the most common causes of issues. If that is not it, file a bug report at bugs.vixenlights.com and attach the logs from the log folder and we can take a look.
