Results 1 to 10 of 10
Thread: Pixel test shows incorrect color - red and green are swapped
    Feb 2021
    7
    Default Pixel test shows incorrect color - red and green are swapped
    I bought a pixel tester from wiredwatts.com and hooked everything up to a single pixel to test but the red and green colors are incorrect. When I hit the red R button, I get green. When I hit to green G button, I get red. I must have hooked up the wiring wrong. I'm using an old barrel connector to power the tester. I hooked it into the power supply which is SPT-1 wire. I wired the the one with the writing "SPT-1 (18 AWG)" to the V+ on the power supply and the other to the V-. If this is backwards would this cause a problem? Other than the red/green being swapped, everything seems to work OK. The blue works correctly for example. Any help you can provide is appreciated. Thanks in advance.
    I've attached a picture for reference on the setup.
    7,264
    Default Re: Pixel test shows incorrect color - red and green are swapped
    If you can access your controllers configuration page , simply change the pixel's rgb setting to GRB and save that configuration .
    Feb 2021
    7
    Itís controlled with a simple pixel tester so it doesnít have any configuration. Itís the one from https://www.wiredwatts.com/testerp3. Itís about as basic as it comes.
    Folsom, CA, USA
    2,368
    Your tester is based on pixels having a sequence Red Green Blue, and that cannot be changed.
    Pixels come in many variation of that sequence. Typically we see string pixel as RGB, and strip pixels as GRB. Looks like this is a strip based device I assume you have string type pixels.
    Edit: oops hit enter in error.
    Since this is to be just a tester. Know Red = Green
    In Lights Therapy
    7,264
    Pixels come in many variation of that sequence. Typically we see string pixel as RGB, and strip pixels as GRB. Looks like have strips.
    He has square nodes it looks like.
    7,264
    The tester is just for proving the pixels work ..
    You will need a control device and /or method of controlling them .
    Feb 2021
    7
    Thank you this was very helpful. Youíre right the tester has a sequence and after a little more research I found how to change it. Hereís the link with the info. https://www.wiredwatts.com/pixel-tester-color-order. Once I changed it it seems to be working great. Thanks everyone for your help!
    Feb 2021
    7
    Quote Originally Posted by RonyRooman View Post
    You were right about this [mention]angus40 [/mention]. I had to change the configuration of the tester/controller. Thank you for your help.
    Lombard, IL
    718
    Rony,
    Keep this in mind. Remember it when you do your setup. "These pixels are GRB". When you setup your display, you will need to correct that order. Either at the controller, so long as that is the only type pixel you have on that output. Or correct it in your software. Change the color output in your sequence. I generally sequence all my pixels as RGB. That way they are all the same format when I test. Most or the time my props that have different types of pixels are unique to the output and I can adjust on the controller. There are times you have to mix. Example, on one output I have two arches, made of pixel strips, and two mini pixel trees, made of bullet pixels. The pixel strips are BRG and the bullets are RGB. I have to adjust the output of the arches in my software for them to work right. I hope this isn't confusing. Just remember, the color order can change from pixel type to pixel type. Keep that in mind when you setup.
    5,207
    FYI: Falcon controllers can mix RGB/GRB etc on the same output using virtual strings.
