Results 1 to 5 of 5
Thread: Using the Export Wizard on Vixen
    Jan 2019
    Paola, KS
    79
    Default Using the Export Wizard on Vixen
    I am using the export wizard with Vixen and I get to step 4 where I can either \\hostname\fpp or use \\ip\fpp. When I put in the ip for example \\162.168.2.10\fpp I can not go to the next step. Any one have any ideas?
    Folsom, CA, USA
    2,362
    Default Re: Using the Export Wizard on Vixen
    Quote Originally Posted by tomas041857 View Post
    That's when you save directly to FPP. Suggest you save to computer disk file in Vixen EXPORT folder of that profile. Later you can import from computer to FPP or FPPs
    In Lights Therapy
    Folsom, CA, USA
    2,362
    Use Falcon Player Sequence 2.6+
    Timing 50 is generally ok.....however I use 25
    In Lights Therapy
    Kansas City Missouri
    2,771
    You can also export a Universe file from vixen but you would have to access the root directory of FPP and upload it. It would then fill in FPP output channels for you. If you donít have a ton of universes you can fill it in manually. I used FileZilla to access the root directory of FPP.
    If I remember correctly the login for FPP is FPP and the password is falcon.
    Maryville, Illinois
    1,963
    Which version are you using? There was a bug that was fixed in last release versions at the end of the year. 3.7u4 is the latest. If you still find an issue with the next button not enabling, then lets create a bug with the steps you took and we can see if there is some other bug there that needs to be fixed.
