Results 1 to 10 of 12
Thread: Another use for RBLs
    Lombard, IL
    704
    Default Another use for RBLs
    I was only able to get ahold of a couple of RBLs over Christmas last year. But I came up with another way to use them. RBCs - Really Big Candles
    Parts list per candle:
    - An RBL,
    - 4" PVC pipe that is 36" long
    - 4" PVC cap
    - Large serving bowl from Dollar Tree
    - Bag of cement
    - Left over J-Hook
    -Drill a hole to in the PVC cap to accommodate the J-hook. Put the hook in the cap so the hook sticks out the top, and bolt it down.
    -Using a hot glue gun, glue the cap, open side down, to the bottom of the bowl. So the hook is in the sticking out in the bowl.
    -Mix up the cement and fill the bowl, I used two bowls together to support the weight of the cement. Let the cement set up.
    -Once cement is set, un-mold from bowl. You should now have a half round with the PVC cap embedded in the top.
    -Insert 36" PVC pipe and put RBL on top. I used two screws through PVC and into RBL to hold the RBL in place.
    -Near the bottom of the PVC pipe I plan on making a hole large enough to allow Pixel cable to go in.
    -Will cut a 10' Pixel extension cable in half to give me input and output connections.
    -RBL has been retro-fitted with 6 pixel insert.
    -Will then paint the PVC pipe Christmas Red with spray paint
    -Apply white vinyl "candle drips" to top of PVC to complete the look
    Feb 2008
    Warminster, PA
    1,754
    Default Re: Another use for RBLs
    Cool! We really need to see them lit though.
    Chris
    Delaware, OH
    4,570
    I look forward to seeing the finished product. And I too would like to see one lit !
    3,027
    Really nice idea.
    Clarksville, TN
    308
    Quote Originally Posted by mikeh65 View Post
    I did something similar, except instead of painting, I wrapped a strip of red duct tape around the PVC to give it a peppermint look.
    -Tony
    Tony
    Live since 2007
    Putting the Yule back into Yuletide
    Lombard, IL
    704
    Pictures of the finished candles, painted and lit.
    Delaware, OH
    4,570
    O u t s t a n d i n g !
    pictures of the finished candles, painted and lit.
    Feb 2008
    Warminster, PA
    1,754
    Wow! They turned out really nice!
    Chris
    3,027
    So now, can I order my set (10) in a specific size?
    Really good stuff here. Very well done!!!
    Jan 2021
    93
    Ho. Lee. Smokes.
    This needs to dot every lawnscape the same way singing Christmas trees do. I could totally throw pixels up the candle and make it look like one of those barber-shop things. These things need to line stuff, like pathways. Like 12 of them.
