F/S 24 Channel DC controller (Kostyun)
That’s right, a genuine frank kostyun 24 channel DC lighting controller.
Flashed with DMX firmware. I forgot I had this.
Make an offer if you can use it.
Chuck P
nothing to show
Re: F/S 24 Channel DC controller (Kostyun)
I believe that is a Ren24LV, which uses remote SSR's. It can accomodate either AC or DC SSR's. The only minor caveat with the controller is that due to it's design, the indicator LED on the SSR won't light up when plugged in to the controller. Other than that, they work just like a Ren64. Yes, Frank designed them to use LED's directly from the board, but I think most folks used them as an SSR controller.
Is this a http://www.doityourselfchristmas.com...e=Renard_24LV?
With the transformer and zero cross chip installed (appears to be), is this really a AC controller? just need some ssrs?
<took me too long to investigate and rstehle had the same thought.>
Some additional info here
Chuck P
nothing to show
- You may not post replies
- You may not edit your posts
Forum Rules
