Results 11 to 14 of 14
Thread: Buy or Make Own Cables
    Dec 2020
    90
    Default Re: Buy or Make Own Cables
    Thank you all for the advice. I will do the same, i.e. use big store cables for major runs. I already have quite a few but need to buy some more. For the rest I will be making my own SPT-2 lamp/zip cord. I need to decide if I want to go with brown or transparent. Maybe transparent, though most will be kind of hidden anyways (behind eaves, under bark, etc so maybe I shouldn't even worry about color). I probably will pick some up at HomeDepot ($56 for 250' for STP-2 and 18/2. Black would be cheaper, i.e. $100 for 1000' at Amazon).
    The main remaining question is regarding the Vampire plugs (can I use them for Christmas too or only for Haloween ;) ) There are so many options and so many sources. Where are you buying those from?
    @todd1814 what is SSR? Solid State Relay? That's the best I could come up with a google search. I purchases a Falcon F48 with some differential control boards. It certainly would be nice to avoid Ethernet cables.
    Feb 2008
    Warminster, PA
    1,754
    As for the color of the wire: You won't see it in the dark.
    As for where to buy the vampire plugs: I usually get mine from here: https://www.noveltylights.com/male-a...-vampire-plugs
    Chris
    Dec 2020
    90
    I contacted noveltylights regarding their 1000' brown zip wire cable that is out of stock. They won't have any until August. What other place are you buying cables and connectors from?
    Feb 2008
    Warminster, PA
    1,754
    I buy the Vampire plugs from novelty lights and just pick up the spt1 from Home Depot or lowes.
    Chris
