Thread: Pixel Pi Cape and FPP Master/Slave
    Chambersburg, PA
    939
    Default Pixel Pi Cape and FPP Master/Slave
    When using a Pixel Pi Cape controller (typical) as a FPP Slave, can a USB>RS485 adapter still be used to connect to a Renard controller?
    2016 - No Display
    1,771
    Default Re: Pixel Pi Cape and FPP Master/Slave
    I have not tried it but the answer should no problems.
    Cedar Falls, IA
    129
    Yes, I actually use usb to serial, but the setting is on the same screen. It is on the other outputs tab as found in manual on page 120. You'll set the start channel and the channel count to send.
    https://falconchristmas.github.io/FPP_Manual(4.0).pdf
