I just got a couple of the McMaster pipes. I can see that the Apollo is not going to work. It is completely white/opaque whereas the ones from McMaster are semi transparent. I will wait for the other one from McMaster to come in. It seems I have to forget about the SharkBite because none of the HDs has 1"+ versions and the 3/4" are at least 300', no matter which HD I look at. No luck with Lowes, either. They also have 100' minimum and the 1.5" one is running $380 ($3.8/foot for 100').
@Kensington, do you have a picture of your setup? I am thinking of using Ts and then put some bricks on them. Maybe have a PVC pipe between both ends. I have bark in the yard so I can hide the bricks and pipe under the bark.
