Results 1 to 5 of 5
Thread: Need help to waterproof power adapter for LED RGB tape light
    Dec 2015
    10
    Default Need help to waterproof power adapter for LED RGB tape light
    Hi all - I am so new to the DIY Christmas decoration. I have some wireframe that I need to replace the incandescent lights with LED. I bought some RGB waterproof tape light on Amazon and zip tie to my frame, and it works great. However both the built in chase controller and 12V power adapter are not waterproof. Can you tell me how to waterproof or change the non-waterproof power adapter to waterproof adapter? Thanks in advance
    Jan 2021
    32
    Default Re: Need help to waterproof power adapter for LED RGB tape light
    here is what i use on plug ends.
    for power supplys u can use rain proof out door 12v or 5v power supplys.
    Sent from my SM-N975U using Tapatalk
    Dec 2015
    10
    thanks so much mr fix
    1,772
    You can bag them. You can cover them with a piece of plastic container. You can put them inside a plastic container.
    Oct 2012
    303
    Wax. What you say? No seriously, way back in the day we would conformal coat circuit boards that would be subject to moisture with wax. I did the same with my pathway light boards. So maybe not a solution for this particular question but if you need to "conformal coat" a board, it may work for what you need
