Results 1 to 4 of 4
Thread: Newby Where do I start?
    Dec 2020
    5
    Default Newby Where do I start?
    Howdy and thanks for the add.
    Total newby and love the idea of lights (pixels). I bought two stings of 50 ws2811 to play with. Did wled with a NodeMCU, OK but want then it dance to music. Took to Vixen like duck to water in sequencing, but cant get it to connect to the lights, tried Dr. ZZZ's d1mini got some to flash but no run the sequencing. Looked at Using the Arduino and relays, but realized that only changes string colors not each pixel. Anything I can read a flow chart? to show me the things necessary to build one of these systems. Thanks in advance for your help. I'm newly retired and get crazy for this type stuff.
    Ted
    4,859
    Default Re: Newby Where do I start?
    ESPixelstick
    Dec 2020
    5
    Thank you, looked and ordered two. Thanks for the help. I’m sure I’ll be back with lots more questions.
    1,772
    WLED will receive e1.31 so you could output from Vixen. Also the NodeMCU will run the ESPixelstick firmware. You might want a more robust power in and data output section but not technically required.
