Results 1 to 8 of 8
Thread: Fpp and seperate show network questions
    centereach ny
    219
    Default Fpp and seperate show network questions
    Hi everyone,
    I知 looking to setup my show to run separate from my home network I have a raspberry pi running fpp and have sandevices controllers. I知 looking for help with the setup to do something like the picture i have attached. A few questions I have is if I create a seperate show network will I still be able to access my show controllers and the fpp wireless if I only have WiFi connected to the Pi. Also I understand I will have to change the IP addresses to my new show network on the sandevices. I知 sure I will have more questions as the answers start rolling in.
    Danny
    Danny Smith
    2008 display:
    -168 renard 24 channels
    -fm transmitter: ramsey 25B
    -light count: 15,000+
    [CENTER]The thing always happens that you really believe in; and the belief in a thing makes it happen.[/CENTER]
    Jan 2010
    508
    Default Re: Fpp and seperate show network questions
    That's the way most setup their show network. The FPP manual and Canispater Christmas videos explain the setup in detail. Check them out.
    Chambersburg, PA
    939
    Another great video is from Keith Westley. It is a couple of years old, but has great info.
    2016 - No Display
    centereach ny
    219
    Thank you guys
    Danny
    Danny Smith
    2008 display:
    Nov 2014
    Close to Hillsboro, OR
    595
    Danny, my display is set up just like your picture and it works great. There's a couple command lines to add so your home router can access all the devices behind the show router that is probably covered in those videos - I didn't watch them to the end but they look familiar.
    Nov 2010
    Manhattan Kansas
    325
    There is also a very good description of setting up a system like this in the FPP manual.
    1,582
    You don't need to mess w/ your router settings with the newer versions of FPP, they have a "Proxy" setting where can add the IP address of your controllers and all you have to do is connect to FPP the go to the Proxy page and click the IP address of your controller to connect to it.
    Nov 2014
    595
    I have them proxied but I added those networking command lines because of the way the Sandevices controllers act sometimes when being called or proxied by using the Pi WLAN.
