Results 1 to 7 of 7
Thread: Controller Question wemos mini
    Jan 2021
    15
    Default Controller Question wemos mini
    First post!!! I have decided to move on with this and have been devising plans. One major piece is the controller. My first display will be the out line of the roof line, ridge, and hips. I really want to use the wemos mini (ESP8266). its cheap and really easy to deploy. While going through the learning material, here and around the Web, I have not really seen it discussed. Is there a reason not to go wireless on a dedicated wifi for the entire display? Another question that seem to elude me is how many universes can be on a single wemos mini while maintaining a good FPS?
    1,773
    Default Re: Controller Question wemos mini
    Many people mix in wireless in their displays including decent number of universes.
    The wemos is is basically the same as a espixelstick and is tested for 680 pixels (4 universes) at 50ms or 20 fps timing. If you haven't bought it yet, you should look to the esp32.
    4,872
    look at the espixel stick series of devices. lots of people do it this way.
    Southern California
    1,197
    My entire show of 3300 pixels and some AC lights (10,075 total channels) is run wirelessly by ESPixelstick type of controllers. The show uses about 20 fully packed universes. All of my sequences are run at 20 FPS (50ms refresh rate).
    I have an ESPixelstick located under my eaves of the second story bedroom. When necessary, I can open a window and remove the screen to reach out and get to the ESPixelstick. So yes, they are easy to deploy and very inexpensive.
    Other posts in this forum have mentioned the maximum number of universes that can be run wirelessly from one Access Point. I think that it was about 26 universes.
    Kevin
    Jan 2021
    58
    The wemos mini is really great for a single mechanical relay, since that is what it has a pre-made Arduino shield for. It has a nice proto shield as well, if you want to drive a mosfet or two with it. Outside of that, I don't regard the wemos mini as particularly better than other small-form-factor solutions out there.
    Folsom, CA, USA
    2,256
    Dan Kulp has some interesting comments about the upcoming ESPixelStick 4.0 and FPP users. May want to wait for more info prior to purchasing WeMos
    Green Site : https://diychristmas.org/vb1/showthr...l=1#post115029
    In Lights Therapy
    Jan 2021
    15
    Thanks guys for the input. Really appreciate your time.
