Results 1 to 7 of 7
Thread: F-Amp Question
    Dec 2020
    42
    Default F-Amp Question
    This seems like a stupid question, but I can't seem to find the answer anywhere. Does an F-Amp need power (V+) to work properly? Or can I run only V- and data through it when doing power injection? I have some props that will be some distance from the controller, and am planning on locating power close to the props.
    - pc
    Kimberly, WI
    312
    Default Re: F-Amp Question
    How far from the controller? And yes it needs v+
    Dec 2020
    42
    Thank you. I'm still in the planning stages, but could go as far as 40'. I have some diff receivers, but in one case, it would only be one string located a distance away, and it seemed a waste to have a diff receiver for only one string.
    I suppose if I run V+ from controller, along w/ V- and data (in order to use the F-amp), I could still inject the prop as I was planning, with almost no V+ from the controller being used. Does that sound right?
    4,872
    Yes the famp needs V+
    Chambersburg, PA
    940
    You can run the V+ to the F-Amp and not bring it out.
    2016 - No Display
    Kimberly, WI
    312
    Quote Originally Posted by puppycrack View Post
    I know you can get 25’ from the controller to the 1st pixel. My longest run. Have you tried it to see if you need a f-amp? I use f-amps when I have a distance from pixel to pixel.
    Dec 2020
    42
    Thank you all for the feedback - very much appreciated!
