How far from the controller? And yes it needs v+
This seems like a stupid question, but I can't seem to find the answer anywhere. Does an F-Amp need power (V+) to work properly? Or can I run only V- and data through it when doing power injection? I have some props that will be some distance from the controller, and am planning on locating power close to the props.
- pc
Thank you. I'm still in the planning stages, but could go as far as 40'. I have some diff receivers, but in one case, it would only be one string located a distance away, and it seemed a waste to have a diff receiver for only one string.
I suppose if I run V+ from controller, along w/ V- and data (in order to use the F-amp), I could still inject the prop as I was planning, with almost no V+ from the controller being used. Does that sound right?
Yes the famp needs V+
You can run the V+ to the F-Amp and not bring it out.
2016 - No Display
Thank you all for the feedback - very much appreciated!
